Kenworth Clarion Stereo FM issues, sound cuts in and out
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by BossModeKenworth, Jun 14, 2023.
  1. BossModeKenworth
    BossModeKenworth Bobtail Member
    Hi there, new to the Forum but with a real head scratcher.
    I have an 09 Kenworth and has given me grief with the stereo since I purchased it last year.
    The only time the stereo works 100% crisp and uninterrupted is when I play music through my phone via bluetooth.
    Now to the real issue, and the symptoms I've noticed through out the months.
    -FM selected on stereo, no 'Chhhhhh' sound, total silence - SiriuxXM not working via FM channel OR AUX
    -When I move truck ahead 1ft. all of a sudden receives FM 'Chhhhh' sound and music works via FM & Aux.
    -then just cuts out again
    -Sometimes when I move my body, arms around picks signal up for a split second, then cuts out again
    -With antenna swinging very staticy connection.
    -Just started cutting out when going down the road and turning steering wheel to the right
    -Sometimes FM works for 2 weeks straight, then all of a sudden giving me grief for days
    -Stereo cuts in and out in cloudy weather, and especially bad when raining and wiper blades are going
    -If FM receives signal and I talk on CB radio, stereo cuts out to normal FM 'Chhhh" sound, only when transmitting signal, not while receiving
    -When I remove stereo while connected, sometimes receives quick signal then cuts out again, dead silence
    What I have tried so far...
    -Clean antenna base with sandpaper
    -Disconnect stereo and blow dust out, clean antenna end that goes into stereo, rewired ground on stereo plug, also check other connections nothing unusual
    -Remove dash and check wires above steering wheel, nothing appeared in contact with steering shaft
    -Wiggled stereo wires & antenna cable hoping it would make a difference, no change.
    -Turn off other electronics inside the truck, without any luck.
    -all antennas on truck are opposite side of each other.
    -Tried positioning antenna differently before tightening (has a small allen screw)
    Thoughts?...
    To me it seems like a frequency interference issue, but why does it work sometimes then for weeks without any major hickups, but other days I can't listen to the stereo at all, all day, as it cuts in and out 100x in a song.
    Also, why would SiriusXM not work via the AUX cord, even tho FM isn't receiving any signal and by that I mean not even a crackling sound, dead quiet, only works if FM goes Chhhhhhh, and at that point SiriusXM also works on FM frequency & Aux.
    Very frustrating.
