Ok ok now that I got your attention I need to know where the fuse for the bunk heater is on this thing it's a kenworth t2000 somebody help please I don't want to idle all night thnx btw it worked last week now it doesn't![]()
kenworth t2000 bunk heater won't turn on I'm freezing help lol
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bigdogg, Nov 20, 2014.
Most bunk heaters have a fuse near batteries in a rubber fuse holder most of mine have been the blue fuse
slim shady and bullhaulerswife Thank this. -
what kind of heater? any fault codes?
You left a lot of info out. You don't want to idle? That's how you get heat. Are you talking about some other heater. We are not mind readers!
semi retired semi driver Thanks this. -
No codes, no check engine lights. I'm just talking about the bunk heater. i can idle the truck and turn on the hvac heater and get nice hot air but then I'm wasting more fuel.I'm just looking for a fuse for the "bunk heater" .BTW I've only had this truck for 2 weeks
are the valves circulating hot water open? if its not blowing at all , fuse, switch or blower motor? not following you about idling
I give up!
x#1, semi retired semi driver, Inland-Pilot and 1 other person Thank this. -
Do you have a fuel fired bunk heater like an Espar or Airtronic that is not firing up? Or what are you calling the bunk heater?
They run off the batteries -
Wait, I'll unpack my crystal ball.......I'll get back to you in a couple of days..................
Skate-Board and x#1 Thank this.
