Kenworth T600 won't crank after sugar found in the tank.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kknight1984, Feb 9, 2021.
  1. kknight1984
    kknight1984 Bobtail Member
    4
    Feb 9, 2021
    96 Kenworth t600 Detroit 60series had sugar in the tank did not crank all we did was wash tanks out let em dry fill both up now can't get it to start run off ether as long as you spray it but soon you let it go it goes dead I was told a bad fuse in battery box and yes I bled the lines and fill fuel filter up any input or something else I can try but gone check fuel first
  3. 062
    062 Road Train Member
    6,217
    33,469
    Oct 20, 2013
  4. jamespmack
    215,830
    Do you have CEL/SEL when you turn key on, no crank?
    96 think its pannel above your head?
    062 Thanks this.
  5. kknight1984
    4
    Feb 9, 2021
    Yes
    jamespmack Thanks this.
  6. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    If I understand you correctly. It does turn over & you are using ether to fire it over it will run. It is not the fuse in the battery box. It is not staying primed it is not fuel going to the injectors. How did sugar get in the tank?
  7. kknight1984
    4
    Feb 9, 2021
  8. kknight1984
    4
    Feb 9, 2021
    Over a girl but we didn't crank cause we seen the sugar on the ground we went ahead and drop tank and cleaned them with a hot water stream
  9. jamespmack
    215,830
    Well being sabotaged is a ruff guess what some monkey could have done. But my guess would be to change SRS, and TRS sensor.
    Only other thought is the power cables l, small 12ga, harness running with starter cables. Has a square plug, about behind battery box, on its way to ecm. Check to make sure its clean.
    New filters and primed? And you hooked lines back up correctly?
    062 and ibcalm19 Thank this.
  10. ibcalm19
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    The tales & acts of an angry woman. Man of man or woman of woman
  11. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    You need to unhook fuel lines at back of eng. or fuel filter with tank lines off tanks too and blow out all fuel that you can replace fuel filter and prime it then look to be sure clean fuel is getting to fuel filter?
