kenworth t660 no idle shuttoff!
Discussion in 'Werner' started by adamrocks133, Dec 5, 2012.
  1. adamrocks133
    adamrocks133 Light Load Member
    65
    5
    Apr 26, 2010
    Look I have a fridge and a tv with an xbox I run at night.. I can run it don't get me wrong.. but it would be nice to be able to idle it atleast for awhile.. I have tried every trick in the book.. I pressed the yellow valve down, put something on tbe clutch, hell I even put something on the fuel peddle and had it stay just right on 900rpms and still it shuts off.. it irritates me to no end.. any suggestions?? Btw I only spend maybe an hour on the game a night..
  3. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    An hour shouldn't run the batteries down enough to notice, unless there is something else wrong.
  4. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Try the red valve.
    You can also press the brake pedal.
    Those two tricks worked for me.
  5. Speedemon1084
    Speedemon1084 Medium Load Member
    381
    169
    Dec 24, 2011
    Collins, MS
    Try pulling down on the trailer brake valve when the shut down light comes on.
  6. adamrocks133
    65
    5
    Apr 26, 2010
    Ok so push the red valve then put something on the brake??
  7. Speedemon1084
    381
    169
    Dec 24, 2011
    Collins, MS
    Pull down on the trailer brake bar on the steering column. You don't have an APU?
  8. adamrocks133
    65
    5
    Apr 26, 2010
    No sure don't.. wonderful isnt it
  9. sdlm
    sdlm Light Load Member
    271
    139
    Aug 8, 2012
    My t660 has unlimited idle, but I don't idle it much. When my cooler, computer, etc use up too much power and the batteries start to get low, this beeper starts going off till put the key in and turn it on.
    DriveItUSA Thanks this.
  10. adamrocks133
    65
    5
    Apr 26, 2010
    Yea I have a friend of mine on the account and his truck # starts with 58 and mine is 59 which is the 2012 model so all he has to do is press the yellow tractor valve in and it idles no problem for him.. I don't need to idle long just enough to get a good charge on the batteries before I go to bed
  11. H-D Road Glide
    H-D Road Glide Light Load Member
    131
    75
    Jun 25, 2012
    Central Florida
    I have a 2012 T660. It only idles when the temp is below 29F outside. I run the bunk heater for about 15-20 min every few hours, and sometimes I'll start the truck and set the ignition timer and go back to sleep.
