Kenworth T680 Sleeper Doors
Discussion in 'Kenworth Forum' started by TruckerPete1990, Nov 6, 2019.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    So one of my sleeper doors is leaking Water from the FRAME itself where it screws into the cab.. Is there a gasket that goes around this frame that can be replaced? When it leaks water its going into my side box:p
  3. stevez57305
    stevez57305 Medium Load Member
    336
    217
    Jan 8, 2015
    Florida
    There should be a gasket that goes around the door closer to the outside it has little plastic rivets make sure they didn't come loose and the gaskets not sitting right also make sure that top window is closed all the way it may look close but when you turn the knob it will close more mine used to find its way open whenever it wanted to until I found a pair of channel locks and show them who's boss
