Kenworth T800 Brake lights
Discussion in 'Kenworth Forum' started by jr33187, Jul 25, 2015.
  1. jr33187
    jr33187 Bobtail Member
    6
    Hi there.........I have a Kenworth T800 and recently my brake light have stayed stuck on. I checked the plunger on the brake and it seems to be going up and down. I noticed if i bleed the air pressure out to almost zero it sends a signal and lights turn off? I dont know what it can be???? Any help or guidance is appreciated.
  3. truckinmachine
    truckinmachine Bobtail Member
    14
    4
    Jul 8, 2015
    have someone look at your lights while you pull up on the pedal. if that dont work unplug the switch on the pedal and see if they go out. they do check continuity in the switch. if its not open when the plunger is depressed get another one they should be cheap
