Kenworth T800 Fuel Cap
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bonder45, Feb 28, 2019.
  1. bonder45
    bonder45 Road Train Member
    1,803
    5,450
    Oct 2, 2011
    Williston, ND
    Just looking to see if any other T800 owners are having small leaks from the fuel caps.
    I’ve tried screwing it off right, removing and trying a different thread, over tightening... nothing works and diesel spills a little bit out of the tank all the time...
  3. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    Check your vent hose, tube or check valve on the fuel tank, it may be clogged, or dirty causing excessive pressure in the tank.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    Are your fuel caps the vented ones ? If so change to non vented ones and install vents in tank fittings by fuel line fittings.
    SAR Thanks this.
