Kenworth Wiring issues
Discussion in 'Kenworth Forum' started by jrbeaves, Oct 6, 2016.
  1. jrbeaves
    jrbeaves Bobtail Member
    I have a 94 T600 Kenworth. Having some wiring issues. I put a new clutch pedal spring in and put everything back together and then my Jake brake didn't work. Is there something that i could have bumped? Also my dash lights are not working at all? Along with my head lights shut off randomly and then turn back on. Help
  3. AModelCat
    158,957
    Jake brake is likely the clutch pedal switch. Check the microswitch on the pedal. Chances are it needs to be readjusted after you replaced the spring.
    As for the lights, if it only started after you had the dash opened up to fix the clutch pedal, look around in the dash for anything you could have accidentally unplugged. Possibly even some chaffed wires that you could have disturbed and caused a short.
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I has trouble with my headlights going on and off on my '00 W900. One of the grounds to the block was corroded.
