Kevin Rutherfrauds $200000 Signature glider truck has complete engine failure!!!
Discussion in 'Ask An Owner Operator' started by Bobby Barkert, Mar 7, 2015.
  1. Bobby Barkert
    Bobby Barkert Light Load Member
    73
    44
    Mar 7, 2015
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    This should get interesting.
  4. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    First post.........hmmm......we have a new contender for the KR fan club presidency.
  5. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Feel terrible for those guys. That truck never seemed to run right; it never got the mpg it should. I hope Bruce & PP stand behind their work.
    As for KR, he has a lot of good information, but I give absolutely zero weight to any recommendation he makes regarding his "industry partners."
    The past & present list includes:
    Airtab
    Bose
    Con-Way
    Counteract
    DAT
    Evans
    FASS
    Fitzgerald
    Fleet Air
    Landstar
    LIPE
    Maxwell
    MD Alignment
    Mercer
    Michelin
    Microblue
    OPS
    Pittsburgh Power
    Polaris Labs
    Rand McNally
    RigDig
    Road King
    Smart Truck
    TST
    Turbo3000
    Some of those companies I use & recommend, but don't expect anything just because KR recommends it -- do your own homework ("do the hard work")
  6. Cat sdp
    Cat sdp . .
    21,057
    73,846
    Apr 8, 2012
    Orion's Belt
    Lifted from that facebook page.......
    https://m.facebook.com/TrackThatTruck
    "Technical update:
    Corrosion has so degraded the head it will have to be replaced.
    A final decision will be made Monday if the block is salvageable. Because the block was counter bored to receive the large inserts we have to see if the new inserts will fit properly in the block.
    Liner protrusion:
    Several issues were encountered when liner heights were measured.
    Background: Detroit liner protrusion spec is .0005” to .003” above deck height.
    Two liners were installed “####ed.”
    #1 cylinder was flush with the block on one side while the other side was .001 below deck height.
    # 3 cylinder was .001 above deck height on one side while the opposite side was .003 above deck height.
    Three sleeves were installed at .0005 above deck height (this is the lowest acceptable protrusion recommended by Detroit).
    The remaining sleeve was flush which is below the minimum acceptable limit of .0005.
    The block was counter bored to receive the large inserts… so the block was properly prepared to accept the inserts."
    I wonder if he'll show up here to defend the truck....?
  7. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    So who built the engine? Fitz?
    I called them one time and did not get a good feeling from that conversation. I think I will get a glider with a factory warranty 2004 engine and add my transmission and drives.
  8. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    No if you read the spec sheet on the facebook page, the truck went from KW straight to Pittsburg Power for their Detroit 60
    Jarhed1964 and Road Killer Thank this.
  9. brian991219
    brian991219 Road Train Member
    2,977
    6,023
    Aug 10, 2013
    Lords Valley, PA
    PP built the engine, the owner of the truck even has pictures of PP building the engine. The failure of the engine should be entirely on Bruce and his crew, they tore down the motor, installed the upgrades, sent out the cam and other parts to MicroBlue, then reassembled it. I think Bruce will stand behind this, but he has yet to comment on it.
  10. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I agree! PP probably has insurance to cover stuff like this. Hard to believe the corrosion in that motor in such a short period of time. I thought about that Evans but decided against it. Seems to me they should be kicking in some funds also.
    Road Killer and YBTrans Thank this.
  11. brian991219
    2,977
    6,023
    Aug 10, 2013
    Lords Valley, PA
    I agree Admiral, Evans should have some liability for the corrosion, if you go to the Facebook page the pictures of the corrosion are incredible. IMHO, Pitsburgh Power is experiencing growing pains, since the California emission rules have sparked a new interest in glider kits Bruce has added staff and increased his volume of work significantly, all while trying to redesign his products to be EPA compliant to settle with the government. Before he "was on the map", he could do a much better job and had much more attention to detail. Following the Facebook post on this truck, they have had many little problems right from the start, including a bad clutch, some wiring issues, and other minor issues that indicate a lack of attention to detail in the build. He has a good reputation and I doubt he will let this be the truck to ruin it, there is way to much public attention on this one failure, situations like this make or break career reputations.
