Kingpin eyes wore out. -Where to or how to fix.
Discussion in 'Peterbilt Forum' started by Flightline, Oct 6, 2012.
  1. Flightline
    Flightline Road Train Member
    2,345
    1,166
    Oct 1, 2011
    Almost There
    I went to replace my kingpins and found one of the eye to have to much play also. Now I'm assuming there is a way to bore and bush it. Will I need to pull the steer axle out and take it to a machine shop or is there a tool someone can come out to fix.
    99 pete. I beleive it is the third set of kingpins. Had Kaiser pins and replacing with Kaiser screw in bushing.
    I'm in Southern Indiana
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
  4. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    I removed the axle and sent it out for repair on the last one I had like that, but it's been awhile. You might call around to a few shops in your area and see who they use for this work.
  5. Flightline
    2,345
    1,166
    Oct 1, 2011
    Almost There
    That is the kit I have and it was easy and great to install. But it doesn't do anything for the eye of the axle.
    Though the vidio would've been easier than reading the directions.
    And they didn't show how hard it can be to get the old kingpin out.
    Nice vidio though
  6. Flightline
    2,345
    1,166
    Oct 1, 2011
    Almost There
    Anyone use the axle surgeons.net? I'm thinking about calling them to come out vs. taking the complete axle out.
  7. MNdriver
    7,985
    4,372
    Feb 24, 2012
    I don't have a press at home for putting in the knuckle bushings. If this is available for my Airtek, guess which way I am going if it's ever needed again.
  8. MNdriver
    7,985
    4,372
    Feb 24, 2012
  9. Flightline
    2,345
    1,166
    Oct 1, 2011
    Almost There
  10. MNdriver
    7,985
    4,372
    Feb 24, 2012
    You can purchase it....
    But it will likely run you $5000 or better for it. Pretty much a portable boring machine.
  11. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    What you are needing is to have the axle bored out and rebushed. This is done with what they call a line bore machine. They make portable line bore machines that will do the job, the thing to watch out for, especially on the king pins, is that you need that bore to be rebored on exactly the same plane as the original bore. If it isn't you would never keep tires on it at best, at worst you might not keep it on the road on straight highway, let alone a curve. Having said this the thing that must always be considered is the man running the line bore, just like in every other field, you have the good and the bad.
    So what you need to know are a couple of things, who has a good reputation running a portable linebore, and is there enough of the old portion of the bore that is not worn, what they always try and do is centerup on a good portion of the old bore, (a section of the bore that is not worn), and this makes things a lot easier, if the original bore is to deformed to centerup on, then it gets tricky, is there a flat surface that is exactly perpindicular to the bore that could be used? I have seen some of the jobs by the axle surgeons, some are alright for what they are, and some aren't, what you run in to in some cases, say on an axle stub replacement, is long after the axle surgeon is gone, in a few months down the road you notice that you can never seem to keep the tires from wearing, and there would be no way of solving this with alignment, (the axle stub was not put on straight). Check the bore and see if there is any portion of the bore that is still straight, (not worn).
    Then call around to your local machine shops and start asking if they have a portable linebore and do they have someone that can rebore and bush your kingpin bore, and is this something that they would stand behind, if the new bore is not on the same plane as the old one. I see that you are from southern Indiana. If you don't have any luck, P.M. me and I will lookup a guy up north of me that is pretty sharp, I still have his info somewhere in a filing cabinet. He has a shop a few miles south of Wabash, Indiana. As far as cost, I wouldn't have a guess anymore, it might be a good idea to check the price on taking the axle to them, and here again, would they stand behind their work, I hope this makes sense, and helps.
    You would need the new components in hand when you have the axle bored, so that they could use the new pins for measurements to make the new bushings. Another idea would be to call the Pete Dealer and ask who they use for a linebore on the axle, a lot of times the service department will give you this information, for that matter, it wouldn't have to be a Pete dealer, this problem comes up at all the dealerships and truck garages.
    Flightline and EverLuc Thank this.
