Kn filters
Discussion in 'Ask An Owner Operator' started by bigNATURE, Jul 13, 2014.
  1. bigNATURE
    bigNATURE Medium Load Member
    304
    86
    May 5, 2013
    Texas city, tx
    Just a quick question, have any of you tried any of the KN air filters?
    If so, which one did you get, how much did you spend, and what are your recommendations on it?
    Especially would like like to hear from anyone using it with an ISX!
    thanks in advance y'all, maybe someone else could benefit from this thread too. Thanks!
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Are you trying to turn your truck into a Honda? :)
    What's the advantage of a K&N? It's a lifetime reusable filter. That's all great but most people don't keep a vehicle a lifetime. Most change vehicles every four years. So those buying K&N filters every vehicle are just wasting money unless they keep the vehicle for several years.
    I looked at their website and they only list up to one of them Freightliner Sprinter vans.
  4. SemperFiServices
    SemperFiServices Medium Load Member
    379
    233
    Jan 29, 2013
    Indianapolis, IN
    K&N will kill your diesel as fast as an EGR. The reason they flow so well is because they have larger filter openings, allowing A LOT more dirt in that most other filters. It's called DUSTING, and it will kill your cylinders.
  5. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    Part of the problem with that is they don't maintain the filter like they should, I ran one on my Dodge and never had a dusting problem at all. The one corner of the filter started to get bad, I called K&N about it, they Second Day shipped one to me, no cost.
  6. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    So they do make them for big trucks?
  7. ladaviscpa
    ladaviscpa Bobtail Member
    4
    yes they do and their oiless
  8. jerry119
    jerry119 Bobtail Member
    Jan 23, 2014
    Bought mine off of amazon for around 130 and have been running it for the past 6 months on an 07 freightliner with an s60. So far so good no problems with it but like others mentioned we do regularly remove it and give it a good cleaning especially with how dusty it gets down here in south texas...But other then the fact that its washable and can be reused over and over no real noticeble difference in mpg, acceleration, etc over a disposible filter.
    bigNATURE Thanks this.
  9. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    K&N's heavy duty filters are oil-less and they are not meant to last a lifetime. The warranty is 300,000 miles: http://www.knfilters.com/search/heavy_duty_air_filters.aspx
    Filtration is slightly worse than paper, significantly better than foam (which is what the fleet air filter is). They actually filter better the dirtier they get (at the expense of flow). But the benefits in flow are overstated (you may save $150/year out of a $70,000 fuel budget). You also pay $150 for 300,000+ miles of use vs $300 in paper filters replaced every 50,000.
    It comes down to whether you want to risk worse filtration for $500 in savings over 2 1/2 years. Me? I say sure. I've run K&N's for 150-200,000 miles on my autos & the only problem was having to spray MAF cleaner one time when I got a bit overzealous with oil (again the semi filters are oil-less). At 98% filtration I figure, a bit tongue in cheek, that instead of going 1,300,000 miles between rebuilds with a paper filter, I'll go 98% of that -- 1,274,000.
    filtration tests:
    http://www.bobistheoilguy.com/airfilter/airtest3.htm
    http://mkiv.com/techarticles/filters_test/2/index.html
    http://www.nicoclub.com/archives/kn-vs-oem-filter.html
    Boardhauler and bigNATURE Thank this.
  10. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    The one I put on my '05 T600 475 Acert Cat worked great for me for 4 years, but I stayed after it maintenance wise. I blew it out every other weekend with low pressure compressed air, and washed it every 60 days give or take a few days so I could do it over the weekend, so I could give it enough time to dry. I sold the truck in March, the new owner likes it so far, but I don't know what his maintenance program like. I was off road about 40% of the time that's the reason for my over kill. I bought mine for increased flow, I can only speak from my experience, but I saw slightly higher boost (very slightly) over the fleet washable filter that was replaced three times under warranty, for the seal falling off. I didn't see enough MPG increase to talk about, but like I said I was off road about 40% of the time, and about half of that was high idle PTO work, so MPS's were not my #1 concern. I was more concerned with being able to clean it frequently, because of the off road dusty conditions.
  11. bigNATURE
    304
    86
    May 5, 2013
    Texas city, tx
    Yeah I buddy of mine at Landstar was telling me how he swears by them and had been running his for years in his freightliner. So, I don't know, I was interested in making a switch. I don't want to allow to much flow that it gets my cylinders dirty? But it seems like a better flow of air would allow the turbo to work more freely allowing the clean air side (Post ERG) to operate more efficiently?
