KW heat and AC
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pheebo, May 1, 2011.
  1. pheebo
    pheebo Bobtail Member
    46
    4
    Aug 13, 2009
    Williamsburg Va.
    I have a 2007 KW W900. I can only get the air to blow at my feet no matter what position the dash switch. Can anyone point me in the right direction to check for problems. Thanks, Phil
  3. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    The switch might be bad or it could be the motor at the blend door. If you can find the harness for the motor on the blend door you can put a volt meter on it when you change the switch to see if it changes. If it changes then it would be your blend door. If it doesn't change then it would be your switch.
  4. dr1c
    dr1c Light Load Member
    75
    11
    Apr 10, 2011
    Alberta
    Sounds like the door is stuck in position....lube up the door components....mine are behind glove box on T800
  5. pheebo
    46
    4
    Aug 13, 2009
    Williamsburg Va.
    I found the problem. A pen or something had fallen into the defrost vent and stuck the door from moving. Thanks for the help.
