kw stack bushings
Discussion in 'Kenworth Forum' started by rollin coal, May 5, 2015.
  1. rollin coal
    rollin coal Road Train Member
    13,272
    26,743
    Mar 29, 2008
    TN
    The verticle bolt that drops down thru the sleeve (sleeve that goes thru the bushing) and goes thru the slotted hole of the bracket (top & bottom part of bracket is slotted).... ...that bolt has a self locking nut on the bottom.
    1) Is that self locking nut just supposed to be tightened enough on the threads to where the stack can move freely backwards and forwards in the slots.
    2) Or do you position that sleeve/bolt in the slot where you want it and snug the self locking nut to where it's locked in that one spot and cannot move back and forth in the slots?
    I've got it tightened to where it can't move freely (2) but it seems like it should be able to move freely back and forth in the slots in conjunction with the ball socket bushing as the truck bounces down the highway?
    But I'm not sure how to set it can anyone with a KW that knows what I'm talking about tell me how to set it? Originally what I had was jerry rigged in the old worn out bushings so I have no idea how this would have been done from the factory. I can post pics if it helps.
  3. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I've worked on Ptb. and they are tight from the factory. My opinion is you have them the way they are supposed to be.
  4. rollin coal
    13,272
    26,743
    Mar 29, 2008
    TN
    Yeah that's what Oscar said. Mine are slotted aftermarket for 6" pipes. Originals from the factory for 5" just have holes drilled in them so really there is no need for play there. They're tight and everything looks good after a little test spin on some rough roads.
  5. sparky88
    sparky88 Light Load Member
    143
    31
    Jan 22, 2014
    oswego, ny
    Yeah my 7s are tightened all the way. The one side loosened up and rattled
