KW T680 water temp stays 220 and doesnt drop even the fan is on
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by iceman9, Jun 21, 2021.
  1. iceman9
    iceman9 Bobtail Member
    Hi guys,
    My 2014 T680 started overheat yesterday while i drive bobtail only!! , it gets to 200 very quick, id say in 10 minutes then it goes up to 220-225 within 7-8 minutes; then fan kicks on and it stays there until i come to a stop, i went to KW dealer, they say engine temp is ok by checking thru their computer, what would cause this issue? Anyone had such thing before? Should i replace the thermostat, water pump and coolant sensor? I even washed the front of radiator and it wouldn't help, please advise if you can, thanks
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Have a shop check the system with an inferred temperature gun and see if its actually over heating, my guess is its not as you stated KW said it was fine with the computer hooked up. Its most likely the sending unit that send temp to the dash gauge thats gone breasts up on ya.
  4. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    Need more info. What was outside temp. Is this something that just started happening the other day? Never did it in past?
  5. bad-luck
    bad-luck Road Train Member
    3,357
    6,206
    Nov 16, 2013
    Baltimore, Maryland
    When KW dealer said temp is ok. Are they saying that it is reading properly? Get yourself a Thermo heat gun, to make sure the temperature is correct. Check the radiator, bottom hose block thermostat area. If the temp is correct, could be that your thermostat is not opening all the way.
    spsauerland Thanks this.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    What engine?
    Goodysnap Thanks this.
  7. Xenergiserx
    Xenergiserx Light Load Member
    107
    60
    Feb 2, 2021
    Maybe it’s unrelated. But drive it a while with the ac off. When ac system gets hot the fan turns on.
  8. AModelCat
    161,291
    When was the last time you cleaned out the rad?
    Xenergiserx and spsauerland Thank this.
  9. Xenergiserx
    107
    60
    Feb 2, 2021
  10. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    Sounds to me like the coolant has poor circulation. What engine?
  11. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Agree, like WP shaft or impeller broken.
