KW T700
Discussion in 'Kenworth Forum' started by BKLusk64, May 15, 2016.
  1. BKLusk64
    BKLusk64 Light Load Member
    106
    59
    Nov 17, 2012
    I am seeing some used T700 for sell. Does anyone have any insight on these. I know KW has stop production of them I think.
  3. Razorwyr
    Razorwyr Road Train Member
    2,284
    2,824
    Jul 27, 2010
    Meridian, Mississippi
    What kind of insight? It's basically a slightly wider T680. KW did stop production, the T680 replaced both the T700 and the T660. It's supposedly the best of both worlds.
  4. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    It has very little in common with the T680 - whole different truck.
    The T700 is pretty much just a warmed over T2000. They've improved some areas - made it easier to remove the cab fairings, for example, and the headlights are much more practical than the bumper mounted headlights of the T2000. Interiors leave a bit to be desired for build quality. Unlike the T2000, the T700 will be equipped with an aftertreatment system (DPF or DPF/SCR, depending on model year). I'd avoid any T700s with a Cat engine, since the T700 was produced in years when Cat wasn't exactly in their prime. Cummins ISX and PACCAR MX engines can also be found in them. Gen 1 PACCARs aren't terrible engines, but they have their quirks, as well as belt tensioners with a propensity to go tits up (Gen 2 seems to have rectified this issue).
    Whatever you do, don't break a bumper bracket in one - given where they've located the bolts for the bumper brackets, you have to lift the radiator to swap out a bumper bracket. I suppose that would be my biggest annoyance with them.
    LumbraX Thanks this.
