L9000/Fld daycab ac
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by W923, Jul 10, 2023.
  1. W923
    W923 Road Train Member
    1,332
    4,061
    Feb 28, 2022
    I put ac in one of my 95 l9000 fords, since ford parts are harder to find and often expensive I used the compressor, condenser, and dryer and switches for an fld120. The only ford parts are the evaporator and orfiice tube. I Got everything put together the other day and charged to roughly 2 lbs had 20 psi low side and 160-180 high with the fan on. The problem is I can’t seem to get the discharge temperature below 55. It’s better than nothing but really disappointing compared to my f700 flatbed truck that will freeze you out on a sunny 95 degree day. One thing I notice is that the condenser is tiny compared to the flatbed truck but I needed something smaller to not interfere with an oil cooler for the wet kit. any thoughts or knowledge on how good:bad the ac on a 9000 would have been?
    Bean Jr. Thanks this.
  3. AModelCat
    157,196
    2 lbs seems a little low.
  4. Star Rider
    Star Rider Road Train Member
    1,422
    11,575
    Sep 23, 2019
    Get your high pressure up to about 300 and low about 30 , when the fan cycles you will know you have it
    W923, Rideandrepair and RubyEagle Thank this.
  5. OLDSKOOLERnWV
    18,186
    273,766
    My bucket of bolts takes 3.5 if my memory is correct….
  6. MRMTRANS
    MRMTRANS Medium Load Member
    360
    389
    Apr 28, 2015
    3.75 lb is stated on the sticker if my 2002 Century with sleeper and a Sanden S7 compressor. 2lb is probably a little on the low end. 3.75 lb usually charges down to 50°. Charge when outside temperature is cool, if you didn't. And I use silicone seals only. They seem to hold up better-over time for sure.
    W923 and Rideandrepair Thank this.
  7. W923
    1,332
    4,061
    Feb 28, 2022
    If I don’t have the fan on it will easily get to 280 ish at which point the fan comes on.
  8. Rideandrepair
    17,284
    56,105
    Aug 8, 2015
    I agree with everyone. 2 lbs. and 20 psi is low. 3 lb.7 oz. on my FLD. 55oz. I put 5 cans, 60oz. Bleed air from line after connecting each can. Works perfectly every time. Unless there’s a problem. Might want to add slowly, giving it plenty time to circulate before making conclusions. When using my Official Guesstimating chart, before I had gauges, I found that filling it, while the compressor is constantly running till the compressor cycles off for the first time. Stop. That’s usually pretty close. Fully charged, the clutch should stay engaged longer than not. Up to twice as long. Much longer, it’s probably low. Cycling off longer than on, it’s overfilled. Running it low will cause the compressor to run hot, and shorten its life. You need that last 12oz. or ? to keep up on real hot days. Mine usually runs at 35 low side. But on real hot humid days, up to 55 when completely full.
    JoeyJunk and W923 Thank this.
  9. W923
    1,332
    4,061
    Feb 28, 2022
    Seems that everyone thinks I should try a little more juice…I will see what happens if I add more tonight or next time the truck is home.
    JoeyJunk Thanks this.
  10. MRMTRANS
    360
    389
    Apr 28, 2015
    280 psi on the high side? If so, that should do. I get 300 psi high side and 40 psi low side when maxed out at 3.75 lb of refrigerant. I charge a little less anymore to get more time out of system before a failure occurs.
    JoeyJunk and Rideandrepair Thank this.
  11. MRMTRANS
    360
    389
    Apr 28, 2015
    BTW, did you use a vacuum pump before charging? I think that's important. Removes moisture as well as air to allow more refrigerant upto pressure limits. Can get one at Harbor Freight relatively cheap.
