Lab Top heating up?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by hazevision4, Mar 12, 2011.
  1. hazevision4
    hazevision4 Bobtail Member
    39
    7
    Apr 9, 2010
    Does anyone have any tricks or remedies to cool their lab tops? I have a mac book pro with a protective shell on it. When it becomes heated I use an ice pack with a cloth or towel raped over it to bring down the temperature. I find using the towel prohibits any condensation and just cools it.
  3. walstib
    walstib Darkstar
    I elevate mine, or lay 3/4 on a book(with vents hanging over side), as the cooling vents are on the bottom...
  4. hazevision4
    39
    7
    Apr 9, 2010
    Yeah I have a protective shell under mine with lil holes which somewhat constricts air flow so i just tried out something new a few hours ago and it seems to be working. I'm not putting the ice pack directly under the unit so i should be safe, just wondering what you'd think about it safe or no? Your remedy seems to be comical also allowing more air to flow around the unit, thanks.
  5. trucker_101
    trucker_101 Heavy Load Member
    941
    639
    Apr 23, 2010
    Alberta
    I use a blow gun every so often to get the dust out of it.
    walstib and hazevision4 Thank this.
  6. hazevision4
    39
    7
    Apr 9, 2010
    Yeah i here that, blowing the unit off reducing fan resistance from dust good idea.
  7. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    I think he means blowing the fans out.... I had to blow my fans out weekly when in the truck. Lots of static to attrack the dust.
    when I had it on the cooling fans I kept a bounce sheet between the cooling fan and the laptop
    Thanks,
    Mark
  8. trucker_101
    941
    639
    Apr 23, 2010
    Alberta
    yup thats what i meant. Turn it up side down an blow from both intake & exhaust side a few times, you'll be amazed at the dust that will come out!
  9. walstib
    walstib Darkstar
    When blowing out the dust be mindful those aerosol cans(if that's what you use like I do) can make the fan go faster than it's designed to and damage it...I usually stick a toothpick or similar in the vent to hold the fan still while I blow it out to avoid damaging it...
    bullhaulerswife and trucker_101 Thank this.
  10. Rockin&Rollin
    Rockin&Rollin Heavy Load Member
    798
    6,325
    Mar 6, 2011
    Orlando Florida
    Good idea that everybody should do often but if you’re a smoker you will likely need to open the case up a physically wipe off the fan blades as they will be sticky.
