lack of power, bad fuel mileage d12d. bad EPG valve?
Discussion in 'Volvo Forum' started by FAP, Sep 24, 2014.
  1. FAP
    FAP Light Load Member
    81
    13
    Oct 14, 2011
    Chicago, IL
    Lately I`ve discovered that I don`t have pulling power, especially when going uphill. It goes away and comes back, but last few days it is really bad. No pulling power, bad fuel mileage (but not horrible) about 5,5 mpg. Now my engine brake is just like my pulling power. Mostly very weak, sometimes not responding at all and very rare it is fully operational. Mechanic with not a lot experience with Volvo engines figured today that my EPG valve is dead (silver small plate on driver side) It is actually not releasing any air when he uses air compressor to send air through it. Now, Is that normal or that means that EPG valve is dead? Repairable or not? After browsing here seems like that is common problem on a Volvo and I did run on a bad fuel few months ago in NJ (actually horrible fuel) that clogged my fuel filters in a matter of seconds no matter how often I replaced them. Pablo wrote that bad fuel can damage EPG valve... I have a feeling when I drive that something is choking engine , maybe engine brake because of the bad EPG valve? btw how do you know that you need to replace boost sensor? any symptoms?
    Thanks
  3. v6killer
    v6killer Medium Load Member
    446
    122
    Dec 6, 2010
    ChicagoLand
    How many miles are on this engine?
  4. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Pull the boost sensor from intake. 2 10mm bolts and it pops right out. If it looks like a bomb exploded the tip of it then it needs to be replaced. Not a hard job. If it's good, put a dab of lube on the oring(don't laugh, I use personal lubricant. It's water based and won't degrade the rubber) then pop it back in.
    As as far as epg, if it's not releasing then I would suspect its bad. But, before you spend $800 on the part, take the four bolt out and remove it. Clean it up really good with some parts solvent, then brake clean then blow it dry with air. This should dissolve the carbon that's making it stick.
    FAP Thanks this.
  5. FAP
    81
    13
    Oct 14, 2011
    Chicago, IL
    View attachment 72328 View attachment 72329 View attachment 72330
    As you can see pictures. Anyway, EPG valve was replaced. Mechanic found the airline coming from epg valve to exhaust pressure governor broken so that`s how he started inspecting all of this. EPG valve did not release any air through itself when put on a compressor (reason for replacement) We tested the truck after that but still same problem. Then exhaust pressure governor was taken out and result you can see on pictures. Piston doesn`t retract all the way back when no pressure and we had to use a crow bar to put it all the way back. We assume that`s what is chocking the engine. Cleaning sounds like the plan. Keep you updated!
  6. FAP
    81
    13
    Oct 14, 2011
    Chicago, IL
    btw, where is boost sensor exactly located?
    Abruner454 Thanks this.
  7. Helowrenchturn2
    484
    140
    Apr 23, 2013
    On top of intake manifold. Right above ECM. Looks like a little bubble with two 10mm bolts.
    FAP Thanks this.
  8. FAP
    81
    13
    Oct 14, 2011
    Chicago, IL
    Engine brake not problem... not EPG valve nor EPG (engine runs smoother and sounds like a Volvo now) Hunt is about to be continued tomorrow. Suspects: boost sensor and air filter. Any ideas?
  9. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Could be boost sensor. Could be faulty injector harnes. Could be low fuel pressure. Any number of things. You might be better off to find someone with knowledge of this motor that can go on a ride along with computer hooked up. An experienced tech can monitor all the systems and sensors. Probably narrow it down pretty quick. Without a boost gauge and pyrometer it's really hard to tell what this thing is doing. You said it comes and goes? My bet would be an intermittent connection. The trouble with that is the ECM is getting input from the sensors so it doesn't throw a check code, it's just incorrect information that the ECM is working with.
  10. Sartaj
    Sartaj Bobtail Member
    Oct 3, 2014
    What's your turbo gauge reading going uphill? Could be a turbo issue
    FAP Thanks this.
  11. awind
    awind Bobtail Member
    Did you find a cure for your lazy engine?
