Landstar BCO flatbed question
Discussion in 'Ask An Owner Operator' started by z32sean, Aug 29, 2016.
  1. z32sean
    z32sean Light Load Member
    110
    179
    Aug 9, 2016
    Middle Tennessee
    I am in the approval process with Landstar and am wanting to go flatbed. I am a little worried about year round freight. Can anyone give me an idea of what to expect? Live in middle Tennessee and can run either skateboard or step.
    Thanks
  3. spyder7723
    spyder7723 Road Train Member
    15,471
    25,077
    Mar 31, 2013
    sarasota, fl
    Not with landstar but know enough about them i can take a stab at this. Open deck freight always slows down in winter, but even when it's slow it is still better than 98% of van freight.
    Say you work 25 days a month in peak season, in winter slow down season you may only work 22. And rates will drop about 10 percent.
    z32sean and Puppage Thank this.
  4. Roadking96
    Roadking96 Light Load Member
    127
    57
    Jan 7, 2016
    i'm currently pulling step-deck with them out of Orlando fl..freight is not tht great right now.the agents do alot of double brokering which kills the the rate & landstar does nothing abt it(Quickest way to tell is when you call and they say hold on let me check to see if it's still available ..and of course you will be on elog which is why i am leaving soon!!!!
  5. spyder7723
    15,471
    25,077
    Mar 31, 2013
    sarasota, fl
    Florida is a black hole for open deck freight. And even so, landstar has some pretty good freight down here. Just like every company, they got good agents out hustling new contracts every day, and they got not so good agents perfectly content to just get brokered loads covered.
    z32sean Thanks this.
  6. z32sean
    110
    179
    Aug 9, 2016
    Middle Tennessee
    How long did the application process take you? My current company driver job took two days and I was in for drug test, two days later I was in a truck. Years ago it took close to a month to get going with FedEx. I only started the process a week ago but I'm ready already!
  7. Roadking96
    127
    57
    Jan 7, 2016
    it took me almost month.you have to keep calling them and stay up on your application.and you may have to wait up to week before you can get your trailer especially step-deck trailer.but you seem like in good freight area you should be ok.
  8. mp4694330
    mp4694330 Road Train Member
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
  9. Heavy Handed
    Heavy Handed Bobtail Member
    38
    7
    Oct 15, 2015
    E-log is why you're leaving? Everyone is going to have to run them soon enough. What are you going to do leave the next place as well?
    spyder7723 Thanks this.
  10. Roadking96
    127
    57
    Jan 7, 2016
    most likely this elog thing is going to fail.and i'm already fixing up 1995 kenworth t600.so if you like being babysit by little computer more POWER to you buddy!!!!
    win-some-loose-less Thanks this.
  11. LumbraX
    LumbraX Medium Load Member
    394
    443
    Sep 12, 2015
    Orlando, FL
    I hope you're right... but if you're not your 1995 truck might be worthless in the next 10 years, maybe less. Good luck. Not to mention Double Yellow stated it best... what happens at a small company when you get a log violation? The log department edits your logs so your compliant. This will be the same for independents if they need extra hours. I hope your 1995 KW runs you a long time without any issues.. but ops with late models will work the system without any trouble. True Story
