What is a good laptop to buy for use in a semi? As a team driver, I'd like to have one to email folks back home and watch tv/dvd movies. I'm concerned about vibration and shock, mainly.
Laptops
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Hammer 2, Jul 31, 2010.
Page 1 of 5
Hammer 2 I have heard on here that if you get a Laptop not to get a "Note Pad" They are the smaller ones and are a bit hard to see, I'm not sure if the person is speaking of seeing it when trying to drive or what? But I would not recommend it.
Hammer 2 Thanks this. -
Whatever you end up getting, be sure not to leave it running with airflow obstructed, even a cool running Toshiba can fail.Those laptop stands have more to recommend them than just convenience, Don't set it up to use when driving, though.
Don't run it on a fiber pad, carpet pad, or on the bunk.
That being said, I prefer the business class computer of any make over the consumer grade, they tend to be more durable.
I've had good luck with my Lenovo Thinkpad, the one I have has IBM on the cover.
You can buy used machines for less, even a Panasonic Toughbook can be affordable if bought used.Everett, BIG RIGGER, truckerdaddy24 and 3 others Thank this. -
Thanks to you all for your input. I've been looking at the "rugged" laptops--whew! 3-4 grand is a bit steep for my budget. I was wanting one to install in the bunk for tv watching, removeable for bringing in the truck stop. I agree that using one while driving is very dangerous, at best--we won't be doing that! Maybe I could find a refurbished one that wouldn't cost so much. Aaahhhh technology!
Less moving parts in a laptop is a good thing! My laptop hard drives are SSD they are loads faster in performance then a regular hard drive and because there are no moving parts vibration doesn't affect them. These SSD hard drives can be installed in any laptop and fit in the standard hard drive bay with ease!
BluesTech Thanks this. -
bornagaintrucker Thanks this.
You can get one with TV tuner installed, but you will have to look around for that.
Toshiba:
http://laptops.toshiba.com/laptops/tecra
Dell:
http://www.dell.com/us/en/business/notebooks/latitude/ct.aspx?refid=latit&s=bsd&cs=04Last edited: Aug 1, 2010
I've had two HP laptops riding around with me, one for a couple years with no problems. I don't have ssd drives but I set the drives to shut off after a minute so it has the same effect. As long as you have enough ram, 2gb or so, it will load whatever you leave running into memory and leave the hdd off while you drive around. If you listen to mp3's just load them onto an external drive so it reads that instead of turning on the main drive.
Page 1 of 5
