What do I need to edit the light control module on my volvo vnl 670 it's a 09. AIso have Cummins insite and a inline 5 adapter.
LCM Module
Discussion in 'Volvo Forum' started by Edgar2191, Dec 11, 2014.
Insite doesn't work with Volvo body ECU. It designed only for Cummins.
BTW I have question will send it to you PM, OK? -
U need the Dev2Tool, else u have limitilng access for 3-4 levels with TechTool. So u can turn DRL on-off ore switch to LED ore HID lamps
DR (VIN code) parametes in not available, Volvo Engine wont starting if VIN codes in ECMs are different, but cummins starts if u have no immobilizer -
Ok thanks Pablo I will try to take this and do it my self dealer wants 400 after I paid 1700 for my headlights.
I have had my truck in 4 times getting the lcm parameters adjusted while I was tweeking my setup and each time it was a half hour to an hour labour max..
The last time I had them disable the low voltage warnings for high beam, low beam, fogs, and marker lights and it was 120 bucks.
That dealer is trying to hose you. My local volvo dealer told me a half hour to adjust the lcm to accept the trucklites -
Hi, Pablo-UA, so if I get the TechToll, I will be able to turn off open circut wornings for headlights?
