LE Monolec Ultra 8800 Engine Oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DoubleBarrel, Apr 10, 2011.
  1. DoubleBarrel
    DoubleBarrel Bobtail Member
    32
    7
    Dec 27, 2009
    Anyone using this oil from Lubrication Engineers? Website claims "No other petroleum lubricating oil, regardless of price, will be found superior in condition to LE's 8800 at the end of any given period of use."
    Shows to be long drain. 30,000 miles is what a local trucking company changes theirs at. That is how I was introduced to this oil. I have been running it for the last 6 oil changes and been changing filters at 15k and oil at 30k. Grant it, it is $26 a gallon but shows to have Monolec which is a wear-reducing additive. Salesman claims the additives are better than when I was doing running 9 gallons of rotella and a gallon of lucas in my c15 acert. Just wanted to see if anyone else is using this brand.
  3. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    All lubrication specialists say LE is propably the best you can get. I think the price is almost triple over here, I don't use it because my truck is so old but if I had a new truck I would be using it. Isn't 30,000 miles quite normal drain interval? Anyway, it's better than that waste of money Lucas.
  4. DoubleBarrel
    32
    7
    Dec 27, 2009
    Yeah, if you go to their site it says that drain intervals are 100k, but I feel much better at 30k as I was changing it a 15k using rotella/lucas
  5. Izlomik Supatrucka
    Izlomik Supatrucka Light Load Member
    158
    20
    Oct 24, 2009
    Texas
    for some reason here lately ive been hearing alot of "there isnt anything wrong with running just some good
    motor oil" when asking people about adding lucas to engine oil....
    You thinking oil brand change may have something to do with what happened?
  6. DoubleBarrel
    32
    7
    Dec 27, 2009
    No, Im just thinkin if I am going to go with LE or Rotella with the new motor from the getgo
  7. Izlomik Supatrucka
    158
    20
    Oct 24, 2009
    Texas
    i stick to my philosiphy....oil is cheap.....run a good quality oil and change 10-15k miles.....yo....megadong
  8. Dealwitit
    Dealwitit Bobtail Member
    4
    5
    Oct 6, 2012
    Murrieta, California
    bought a 2006 KW w900 with a C15 Acert only 519,000 miles on it, should i go with LE or stay with Rotella? run long hull. would appreciate any recommendations!! Thanks (First time owner operator)
