Lead quad axle vs lead tri w/pup
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Trucknlyfe, Oct 14, 2019.
  1. Trucknlyfe
    Trucknlyfe Bobtail Member
    46
    Nov 12, 2017
    I’m looking to purchase an end dump I’m more so leaning toward a lead quad axle trailer as I’ve mostly used them but I see a lot of trains available locally mostly tri leads, so my question Is which is more ideal I will be doing asphalt & demo. Do people run tris with pup just for the added loading capacity?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    I don't think you are looking too deep. But this is probably the last of your sane questions bfore you slip off this slippery slope.
    The 4 axle lead trailer would be able to carry the weight. Which probably will be where it's at anyway you lol a lot of weight. Edit, this keyboard is getting to need are Replacement.
    Trucknlyfe Thanks this.
  4. Trucknlyfe
    46
    Nov 12, 2017
    So basically stick with the quad got it. I was more curious as to why I see so many people run pups with tris I’m guessing just added loading capacity?
  5. x1Heavy
    34,016
    42,139
    Mar 5, 2016
    I don't know what they think. My last dump truck had a tri under it for weight purposes. The beaver that came with that had many many many wheels under it. Slap and chained 20 ton or more to that thing. It was not a very fast truck, but when everything is in order I might have to wait a moment or a precious minute rather The principal usually delivered a careful sermon.
    Im going to have to replace a keyboard this week. This one lasted 4 years and it's had enough.
  6. Long FLD
    Long FLD Road Train Member
    12,540
    52,140
    Mar 4, 2015
    Where do you live? What are the weight laws? Would the extra payload and revenue justify the added expenses that would go along with pulling another trailer?
  7. Zigzag777
    Zigzag777 Medium Load Member
    460
    514
    Mar 25, 2013
    Down Yonder
    Asphalt would be tough with a pup. Backing up to the paver with a pup. Maybe there’s a way never seen it where I’m from. And where do you put the pup when empty? To unload the dump?
  8. Trucknlyfe
    46
    Nov 12, 2017
    I’m in Michigan. I’m starting to observe that those tris with the pup are mostly hauling gravel and dirt/sand etc and are made of aluminum which you can’t use aluminum to haul concrete & asphalt
  9. Trucknlyfe
    46
    Nov 12, 2017
    I guess my next question would be can you place a liner in those aluminum tris & quads guts to have the ability to haul rocks & broken concrete?
  10. Feedman
    Feedman Medium Load Member
    417
    6,417
    Aug 17, 2015
    West mi
    Axle spacing and groups for the weight. Lots of different options. Are you talking about broken concrete or crushed? Tons of people run aluminum trains with gravel and yes you can get liner's in them. What side of the state are you in?
  11. Trucknlyfe
    46
    Nov 12, 2017
  12. Trucknlyfe
    46
    Nov 12, 2017
    I have an option to get a 1988 all steel quad axle 28 footer I’m guessing probably 40-45k empty not really sure but are those older sets still ideal?
