Leaf springs?
Discussion in 'Ask An Owner Operator' started by dashaker, Jun 18, 2024.
  1. dashaker
    dashaker Light Load Member
    54
    12
    Aug 7, 2014
    Practically New tires less than 30,000 miles on them...do the leaf springs have to be replace or is this something a commercial alignment place can fix Screenshot_20240617_212139_Yahoo Mail.jpg
  3. Pepper24
    Pepper24 Road Train Member
    2,098
    1,640
    Dec 3, 2010
    I personally have no idea what they’re talking about leaf springs offset.Are they saying the springs have no arch ?Leaf springs themselves don’t fail that often.More likely bad Chinese tires then springs
  4. AModelCat
    164,498
    What is their definition of offset? What do the springs look like?
  5. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    My guess is the leaves are shifted , crooked or not in line. May have nothing to do with the tire wear.
    Need more info-
    Year make model. Photos of springs and steer tires.
  6. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    Springs are a fixed item. They have no adjustment. Unless it's an older truck with springs in the rear.
    Another idea would be worn or broken springs. Occasionally you see a truck where one side sits lower then the other side.
    Rideandrepair Thanks this.
  7. Allow Me.
    10,766
    12,575
    May 28, 2009
    Rancho Mirage, Ca.
    I must say, that's a well itemized estimate....even down to the $1.76 charge for washers !
  8. SmallPackage
    5,777
    18,539
    Dec 20, 2019
    Marion Texas
    Spring “offset” can be one of two things. 1) Shifted/####ed to one side or the other due to worn shackle/hangers. Kind of like a toe in/out condition. 2) sitting twisted on the axle pad mount because of severe weakness/sag or loose/bent u-bolts or broken center bolt allowed them to shift forward or back in saddles. This is why checking the u-bolt nut torque is a good idea every year or so.
    springs can be “adjusted” by either re-arching them or using wedges/spacers on the saddles to reposition them at different heights/levels.
