leak under rocker cover on top of head m11
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Apr 18, 2012.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    hey guys i have had this little leak for about a year..it leaks between the cover and the top of the head i guess that make sense but i think i would like to have it fixed..i have to have the valves ran soon so i thought it would be a good time to do the gasket..what should i be looking to pay for something like this???????no jakes or anything just a 1997 m11 +..thanks mike
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    You have to remove rocker assy all six inj not really a bad job make sure to use a little silicone on the gasket and also make sure the rocker box is true this is a common leak when you put it back together make sure you adjust the clearence on the rocker shaft stands I can get you the info if need be.you will need rocker box gasket valve cover gasket and inj o rings make sure you check the injector harness where it plugs in on the outside of the rocker box.also check for coolant in the inj bores l10,m11,ism are common to have leaking coppers
  4. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    Your tearing everything down to the head. Probably looking at a good 8 hours or so.
  5. earthmover
    563
    20
    Jan 27, 2009
    wow didnt think it would be that much time or work to do.lol what would you guys do at this point??? its not stopping me from working but i do have to add a little more old between changes about 1/2 gal. 15thsmiles..its a lod truck but good 1 so for...i may just be better off waiting on the end of the season since i can then just put it in the shop and want really miss work..also if you dont mind truckmechainc please give me the list and what not i really app. it.....thanks guys mike
  6. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Ok I will photo copy them and post them later tonite when I get home
