Every time I pop in Parkin brake valve it starts to leak behind dash. I looked behind there and found a fitting that was leaking like from an exhaust port with two wires on there . What can it be? Is there something that's making it exhaust air from here ? I uploaded a pic hope someone can help
Leaking coming behind dash when I pop in parking valve yellow valve
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nestor, Mar 27, 2017.
Looks like the pressure switch/sensor is leaking to me. If it's just leaking around the threads, snugging it up could work. Just don't strip it if you don't have a spare lol. I'd take it off, check threads and apply thread sealer myself.
Dave_in_AZ Thanks this. -
It leaks around the base. You have to replace it. In my truck it's for the cruise control, 379. Same place, behind the dash. I have replace 3 in 10 years.
If it's the cruise control switch, I think you can bypass it. Undo the air line and plug it. But remember that the cruise control if it's on, it won't come disengage automatically when you hit the brakes. Or maybe it the cruise control won't work at all. Don't know, but I heard you can bypass it. I just replace mine everytime it goes bad.
I don't think it's leaking tru the threads . I think there's a hole in between the two studs where the wire goes . It only leaks or exhaust when I push in the yellow valve
CK. for a crack in the part that switch screws into, if you cant buy a new one look in truck junk yards for a used one?
Diesel Dave Thanks this. -
You just dont get it..... it's junk buddy. Replace it. You can't fix it.
I thought like you, I thought it could be fix, once you take it apart, you will understand. Buy two of them, you will be replacing another sooner than you think.
x1Heavy Thanks this. -
I forgot to mentioned, it's a dealer item only. At least for my 379 it was.
It's a bendix made valve, no reason to be dealer only.
