Leaking Coolant
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BRD TRANSPORT, Mar 2, 2022.
  1. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    03 Pete. C15 13 SPEED.
    LEAKING COOLANT AT COOLANT FILTER. ?.
    DONT GET ENGINE HOT MUCH JUST PULLING GRADE
    FAN COMES ON ABOUT 200' AND COOLS DOWN FAST.
  3. Rideandrepair
    17,357
    56,319
    Aug 8, 2015
    Figure out if it’s a hose, or the filter, or the filter base. May have a hairline crack, happens a lot on fuel filter bases. Probably just a hose. Most have shutoffs on both sides of the filter. Does no good if a hose breaks. Need shutoffs at the supply point for the hoses, making it easy to change a hose, though might lose a bit when changing filters. Not a big deal. Maybe you can change the hoses fast, to eliminate needing to drain all the coolant. Catch what you can. Top it off afterwards. One long hose, to bypass it for now is another option. Maybe you just have a loose clamp?
    BRD TRANSPORT and Roger McG Thank this.
