Leaking emergency shutdown fitting?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by tscottme, Jun 29, 2018.
  1. tscottme
    tscottme Road Train Member
    We just got some new 5000 gallon liquid tankers we use for HazMat. Near the nose of trailer is the standard emergency shutdown device that looks like a bronze pencil without a point. A driver called me and asked what to do, his is leaking. It looks like it's been cross-threaded into the hydraulic line.
    I'm new to tanker & never thought about this possibility.
    What fluid should I carry if I had this problem?
    Do drivers carry spare shutdown fittings if that's what they're called.
    Can a driver remove & replace that shutdown device himself, or is it be left to mechanics since it's a safety item?
    HOW & where does a driver add fluid to that system? Do you add fluid at the jack that opens the internal valve?
    Thanks
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Yes add fluid at the jack, The bronze pencil looking thing snaps off where it gets thin at, then it releases the pressure on the line going to the internal valve. Once it's used it must be replaced. it just screws on with a small wrench, and yes your driver should always carry an extra one.
    tscottme Thanks this.
  4. scythe08
    scythe08 Road Train Member
    2,833
    3,638
    Mar 19, 2007
    Portland, Or
    My last company used antifreeze instead of hydraulic fluid lol. And yes, carry spares
  5. kemosabi49
    10,654
    45,668
    Jan 13, 2013
    SW Arkansas
    We used a fluid that had anti freeze in it. As for the OP, if the shutoff fitting is cross threaded, driver could try to remove it. Then try to reinstall it without the cross threading. Otherwise. keep the system full. I had one once with a leak I couldn't fix and I had to keep pumping it up the whole time I was unloading to keep the internal valve open.
