Leaking (From Exhaust) Leveling Valve
Discussion in 'Experienced Truckers' Advice' started by STexan, Dec 6, 2018.
  1. STexan
    STexan Road Train Member
    14,219
    26,944
    Oct 3, 2011
    Longview, TX
    I picked up an empty trailer yesterday in Idaho. Loaded this morning. I notice now that I’m heavy, there is a little air constantly coming from the exhaust port hose on the leveling valve
    The trailer is riding at proper height. Has been well below freezing since I’ve had the trailer and I’m thinking POSSIBLY there is a frozen water issue inside the valve. Or the valve is just defective.
    Problem is it may be well into the weekend before temp rises above freezing, if it ever does. (Going to Buffalo) to see if the issue clears up.
    Moisture (frozen) is just not an issue we ever see in our equipment but I can’t rule it out. I’m trying to think of an easy way to warm the valve for a half hour or so without burning down the truck or melting air lines. I suppose I could disassemble and remove and sleep with it.
    I’m also considering air line antifreeze but I’m really hesitant to use something that may not work (may not be an ice issue) and may cause more problems.
    It’s not an issue except for causing the dryer to cycle every 2.5 minutes.
    Thoughts? Thoughts about air line antifreeze useage in a trailer system with air bags and other sensitive components?
  2. STexan
    14,219
    26,944
    Oct 3, 2011
    Longview, TX
    I’m planning on running it by a Great Dane dealer in Cheyenne tomorrow but hope it doesn’t turn out to be an ice issue but it is, I’d like to get it dealt with ASAP
  3. 062
    062 Road Train Member
    1,468
    1,405
    Oct 20, 2013
    Does it look fairly new? Might have been changed out and lines hooked up wrong.
    Wiggle the arm where it comes out of the valve. If it changes the sound,valve is worn out.
  4. STexan
    14,219
    26,944
    Oct 3, 2011
    Longview, TX
    All of our stuff is fairly new. This trailer is an 18 put in service about 12 months ago. All looks like original equipment
    However that said. I did “try and move the still attached arm” again, this time the leak stopped and oddly enough, the bag pressure gauge now registers (it didn’t show any different after I loaded this morning. It showed as if I was empty). I’ll just write all this off as “cold gremlins” for now and keep my fingers crossed and see about getting another load to Maui.
    I’ll ask the shop tomorrow (if it acts up again) and it’s still well below freezing if they recommend antifreeze and if so what kind and how to administer.
  5. 062
    1,468
    1,405
    Oct 20, 2013
    Well if you plan to get it looked at tomorrow, you may have to live with it.
    If it’s ice and you dump the bags they may not air back up.
  6. Makeajump
    Makeajump Light Load Member
    249
    181
    Apr 19, 2014
    Texas
    Use a hair dryer and wrap it in towels to hold in the heat. It will warm up and any ice inside will melt. I keep a hair dryer in the truck for such occasions. It gets very hot on the hi setting. I also use it to peal labels, placards and logos off. No scraping.
    062 Thanks this.
  7. STexan
    14,219
    26,944
    Oct 3, 2011
    Longview, TX
    I thought about that but would have to buy a 100 foot extension cord to run off of the inverter and wasn’t really sure it would power it especially across that length of cord.
    But it’s not leaking any more for now
  8. STexan
    14,219
    26,944
    Oct 3, 2011
    Longview, TX
    And based on the tiny bit of movement of the arm that caused the leak to stop, I’m leaning towards a faulty valve that doesn’t like cold. I expect it may act up again once I get rolling tomorrow. If so, it will probably do so early and I can get it replaced up the road in Cheyenne
  9. mpd240
    mpd240 Heavy Load Member
    758
    1,294
    Sep 17, 2011
    Minnesota
    Airline antifreeze. Fifteen min. Tap valve lightly with hammer.
  • Draft saved Draft deleted
