Leaking oil after clutch replacement. Where is it coming from?
Discussion in 'Ask An Owner Operator' started by 77fib77, Apr 27, 2019.
  1. whoopNride
    whoopNride Road Train Member
    1,649
    5,015
    Jan 13, 2008
    Miss.
    Won't hurt to drive, just keep an eye on your oil level, and it is going to make a big mess until you get it fixed.
  3. 77fib77
    77fib77 Road Train Member
    11,299
    73,373
    Jul 7, 2010
    St Louis
    That's what I think too. Ill go to a farm and fleet type store. Get 5 gallons.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    this is not the rear seal. OP what is the mileage of your DD15 ? Close to 800k ?
  5. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    it's not an inspection hole. that place is for engine barring tool.
    Vampire and 77fib77 Thank this.
  6. 77fib77
    11,299
    73,373
    Jul 7, 2010
    St Louis
    392k. It's a 14.
  7. PE_T
    PE_T Road Train Member
    I’m just going by what I was told. The OP seems to have a Freightliner Cascadia like mine. I bought that cover plate some time ago.
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    ok.
    stop the engine and go under the truck. put your finger into that square hole. if you see oil is coming from inside then you have bad rear seal or cracked grear housing. I don't think you will see oil in there. this oil is coming or from fuel pump shaft seal, or from fuel pump big o-ring , or from air compressor big o-ring. 90% you will have leaking oil pump shaft seal. Mine is leaking too. ))) Sometimes oil pan gasket leaks from rear corners and create this kind of mess. Also check to see if this oil is coming from rear area of valve cover.
    77fib77 Thanks this.
  9. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    All good advice. Just seems odd that the leak didn't show till replacement of rear seal. I know oil blows around and makes a mess, but follow up on that mess and see if any other areas look clean that are bolt together with a seal or gasket in between. Sometimes right where the leak originates will be cleaner. Except for the oil of course. Like clean oil coming out.
  10. 77fib77
    11,299
    73,373
    Jul 7, 2010
    St Louis
  11. 77fib77
    11,299
    73,373
    Jul 7, 2010
    St Louis
    New oil is washing the crud off.
    Vampire and stillwurkin Thank this.
