Leaking oil after clutch replacement. Where is it coming from?
Discussion in 'Ask An Owner Operator' started by 77fib77, Apr 27, 2019.
  1. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Usually 12 to 15hrs
    Rideandrepair Thanks this.
  3. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    I would say they owe you a new clutch along with the seal, who did the work?
    Rideandrepair and Dave_in_AZ Thank this.
  4. 77fib77
    77fib77 Road Train Member
    11,302
    73,429
    Jul 7, 2010
    St Louis
    This first one is the plate on the driver side of the clutch housing. With small ball bearing on it.
    These are of the clutch housing. It's wet in there.
    IMG_20190428_124311939.jpg IMG_20190428_124341256.jpg IMG_20190428_124320114.jpg IMG_20190428_124413739.jpg
    Rideandrepair and Tug Toy Thank this.
  5. 77fib77
    11,302
    73,429
    Jul 7, 2010
    St Louis
    Ball bearing
  6. Dave_in_AZ
    411,561
    Some are even 600K.
    Rideandrepair, 77fib77 and mhyn Thank this.
  7. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    But it still sees like last shop is liable
    Rideandrepair, Dave_in_AZ and 77fib77 Thank this.
  8. Dave_in_AZ
    411,561
    Just wow. This sucks man.
    Hatchet job.
    I'd keep and take plenty of pics and take @Ridgeline 's advice and just take it to a proper shop.
    Then take dude to small claims. Get the BBB involved as well.
    It's painfully obvious what happened.
    Hope you don't stress too hard.
    Rideandrepair, Cam Roberts and 77fib77 Thank this.
  9. Rideandrepair
    17,430
    56,538
    Aug 8, 2015
    It happened to Me when I had a trans installed. Started leaking due to housing bolts left loose. Had it removed and installed properly, went back with documentation, along with added down time lost revenue charges. The Guy got the message it would cost more if gone to court. He reimbursed Me, Sounds like you gave him his chance. He should have investigated and even if it was something else. Fixed it and billed you. Sounds like He’s dodging it now. Good Luck. Small claims court if needed.
    PE_T, Dave_in_AZ and Cam Roberts Thank this.
  10. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    So the oil is coming from inside of bell housing ?
  11. 77fib77
    11,302
    73,429
    Jul 7, 2010
    St Louis
    It looks like. Or the way I'm thinking of it is; I went down a gallon of oil in 300 miles/ 21 hours. There is only one way oil can get into the housing, the rear seal. Yeah it inside the housing. The clutch looks dry. I'm guessing drips to the bottom gets blown around by the spinning clutch assembly. Which is why the fork is wet on all sides and the walls are wet.
    Dave_in_AZ and Rideandrepair Thank this.
