Leaking tank vents volvo vnl
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by J Villa, Feb 16, 2018.
  1. J Villa
    J Villa Bobtail Member
    Feb 16, 2018
    Hey guys i have a 2005 Volvo vnl cummins isx
    With dual 150 gal tanks ive noticed that my fenders keep getting sprayed with fuel after investigating i noticed the leak is coming from the vents both hoses on the vents show wetness. It doesn't leak while idling but once i hit the road it sprays my fenders which has also caused a significant decrease in fuel economy. Hopefully someone knows what could be causing the problem thanks
  3. boneebone
    boneebone Road Train Member
    2,295
    2,366
    Mar 13, 2009
    The vents have a check valve that screws into the tank, remove them and clean them as they could be clogged and staying open or replace if defective.
    J Villa Thanks this.
  4. J Villa
    Feb 16, 2018
    Thanks boneebone im going to check that today hopefully it works
    boneebone Thanks this.
  5. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    393
    Dec 4, 2016
    Erie PA
    We had an update from Volvo, an extended hose up the back of the cab, with a filter at the end. Not sure if this was the reason or not.
  6. J Villa
    Feb 16, 2018
    Problem fixed thanks guys it was the vents
  7. TCF
    TCF Light Load Member
    123
    66
    Nov 17, 2015
    I'm having a similar issue, 2007 Volvo vvl, Cummins isx, no fuel filter behind cab. Had a tank leveling issue last year. Replaced the breather valves last year and blew out all of the lines and fittings for the entire fuel system as well as drained the tanks and flushed them out.
    A few months ago the passenger side breather started leaking...not much and not enough to really worry about. 2 weeks ago I replaced the passenger valve again.
    As of today the problem is much worse....when I stopped at a customer for maybe 10 minutes (200+ miles after fillup probably almost 1/4 fuel gone) there was a sizeable puddle of fresh diesel under the tank and the bottom as well as the back of the tank was wet...the hose for the breather had a drip on it as I looked at it.
    The tanks seem to be draining "equally".
    This is driving me nuts and if it gets any worse its going to shut me down while I take it to the shop, let them replace a bunch of unnecessary parts and then still probably have the issue.
    Any ideas would be welcome. Sorry for the long post.
  8. AlexGVA
    AlexGVA Bobtail Member
  9. AlexGVA
    Hi, did you fix this? Just bought 2007 Volvo with same problem at the passenger side.
  10. TCF
    123
    66
    Nov 17, 2015
    I didn't.... No one responded with any ideas.
    It randomly stopped doing it.... Up until recently and it's not as bad as before? It seems like it's a cold weather thing...
    I'm thinking I'm going to run some beer line tubing long and higher than the top of the tank so hopefully it doesn't leak? Just fills the tube?
    Since it's a 4in tube that drops down the side of the tank I'm thinking longer and above might help? I'm sure that breather isn't supposed to let anything back in but it also shouldn't be letting fuel out like that....
