Learing to shift gears
Discussion in 'Questions From New Drivers' started by ken83, Mar 9, 2013.
  1. ken83
    ken83 Bobtail Member
    12
    Mar 9, 2013
    Terrace bc
    looking for any advice on shifting a 18 speed, i can double clutch kind of going foward but needs help downshifting, just haveing trouble with my rpms, maybe going to slow and letting rpms down to low, and whats a good gear to up a steep grade fully loaded...
  3. Giggles the Original
    Giggles the Original Road Train Member
    honey its gonna depend on the % of grade, what gear the truck is able to pull the hill in....
    kerosene jockey and MJ1657 Thank this.
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Practice Practice Practice
    Numb Thanks this.
  5. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    The one that doesnt spin the engine too fast or too slow. It aint rocket surgery.
    Dont look at the tach, look at the boost gauge, keep that gauge as high as you can. As long as you are putting pressurized air in the engine, you are making torque. If you lug it or get to the top of the torque curve you are not as efficient as you could be. If you are going to error, do it on the side of too many RPM, you wont hurt the engine, you just wont go as fast. On the other hand, lugging an engine that does not have gear down protection can overheat the top end and cause engine damage.
    Numb Thanks this.
  6. TripleSix
    129,777
    If he's currently in BC, I would say anywheres between 8 and 13% grades. I was trying to figure who would put a rookie in an 18 speed, but then looked at his location. There's some SERIOUS pulls in the Canadian Rockies.
  7. thelushlarry
    thelushlarry Road Train Member
    3,023
    8,999
    Jan 9, 2012
    glasgow ky
    It is all in learning how to tap your feet do not worry about looking at the shifter
    ken83 Thanks this.
  8. bstromback2002
    bstromback2002 Light Load Member
    133
    24
    May 12, 2012
    wi
    One thing that helped me out that I had to learn on my own was flipping the switch to split the gear just as you slide it in to a gear. Also being a 18 speed I would imagine yours is gonna be pretty close to the same as my 13 there is about a 200 rpm difference between all the gears on the high side of the transmission. Also be very gentle with the throttle. Don't get frustrated and learn from your mistakes. Also shifting at a lower rpm while your learning will help to at least it did for me.
    Hope this helps
    ken83 Thanks this.
  9. ken83
    12
    Mar 9, 2013
    Terrace bc
    I have dual citenship and thinking when i finshed school and get my cdl, was currious what trucking companines is good to start out with, i was thinking of CR England,
  10. ken83
    12
    Mar 9, 2013
    Terrace bc
    oops i mean move back to states and start driving down south, i find it here in canada everyone wants 2 to 3 years experience and looking down south, i am seeing alot of compaines hireing with no experience, just would like to get my feet wet and get some miles on my belt
  11. bstromback2002
    133
    24
    May 12, 2012
    wi
    I also found double clutching made it harder. I pretended when o
    I took my test.
