Learning experiences with Flatbedding
Discussion in 'Flatbed Trucking Forum' started by AndrewMemphis, Mar 25, 2013.
  1. AndrewMemphis
    AndrewMemphis Light Load Member
    61
    15
    Jan 5, 2013
    Southeast region
    Dear all,
    Did anyone here used to drive a regular tractor-trailer? What was the main thing, which you had to get used to when you started Flatbedding? I also wonder when you go to a shipper, consignee, or stop -- do you have to back in to places a lot of times the way most tractor-trailers do? I haven't seen Flatbeds do much backing except for at truck stops. Most of the time it seems that you pull along side a building, or pull through an entrance and machinery takes your equipment off the bed for you. I'm interested in your replies! :biggrin_255:
  3. critters
    critters <b>Late For Dinner</b>
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    there are times you still need to back into places,and occasional docks,like when loading tractors,tarping would probably the hardest thing getting used to,until you figure out what your doing
    MJ1657 Thanks this.
  4. JayTee
    JayTee Light Load Member
    248
    151
    Feb 14, 2013
    While I'd agree that tarping blows, tying stuff down so it's secure would be the big one in my book. and yes, there are a lot of places you have to back into.
  5. neqoda
    neqoda Bobtail Member
    20
    9
    Mar 31, 2012
    Western NC
    The tarping is the stuffest part of it, when the wind is blowin like crazy. There is a myth that flatbeders don't have to back up, thats just what that is, a myth. There will be lots of times you'll have to back up. I loaded out of two different USG's plants and had to back into a building. It's like backing into a black hole. Get yourself set up right and go slow, you'll be okay. Some docks are level with the bed and some aren't. For the ones that aren't they have tarppin stations. One more thing, flatbeds don't have walls! make sure your load is tied down and mind the curves!
  6. TripleSix
    132,666
    I started out pulling reefer. The main thing I had to get used to was climbing up and down the trailer. Theres a technique to tarping...once you figure it out, tarping isn't hard at all.
    critters Thanks this.
  7. dirtyrabbit
    dirtyrabbit Medium Load Member
    416
    158
    Jun 19, 2011
    KS
    It may not be complicated, but sure is the most psychical part of the job!
  8. .verticallychallenged.
    .verticallychallenged. Light Load Member
    60
    15
    Jan 23, 2011
    Vancouver, BC
    I'm delivering to a lot of jobsites, where they need me to back against a crane, or around random other crap they strategically place in my way... I pulled van OTR for a year and a half before doing this, so bumping docks definitely helped me. Didn't help with the physical part though, as dirtyrabbit mentioned... :p
  9. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Flat Bedders call it "gift wrapping". a 24' tarp weights about 80 lbs. X 2 on a flat bed, lots of work. Save your back, don't be a Macho Man like me. Get the fork lift operator to lift them up for you. If he won't go ask his boss. My back is shot after years of being foolish.
  10. .verticallychallenged.
    60
    15
    Jan 23, 2011
    Vancouver, BC
    I'm lucky that what I haul doesn't require tarping, however, when I have to break out the 1/2" chain, I'm still feeling it pretty good the next day...
  11. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    Ya, backing into/out of job sites more then makes up for all the places you simply pull up to a crane and have stuff pulled off your deck. The ultimate is when the crane that unloads you has to lift up your trailer to get you out of the place they unloaded you. Had that happen in Baltimore once at a college I delivered steam pipe to. Fun fun fun.
