Leasing with a carrier AND retaining own authority
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by tnc110, Feb 1, 2025.
  1. tnc110
    tnc110 Light Load Member
    135
    81
    May 22, 2016
    How can I lease onto a carrier and retain my authority. I think the biggest obstacle is cab card showing who is responsible for safety.???
  3. NorthEastTrucker
    NorthEastTrucker Heavy Load Member
    997
    1,868
    Sep 21, 2019
    Ironically, I had a sitdown meeting with another carrier regarding a similar situation. As we spoke about my potential on boarding with their company a few ideas occurred. They were even considering that I can keep my authority whiles operating with them carrying and shipping freight. From a cost effective means, they saw some savings on their end. Unfortunately, because of my Equipment setup, things did not pan out. I would suggest speaking to their Management, Recruiters and Owners if their willing to have a sitdown face to face meeting. Some larger carriers in these times will admit that this economy has effective every trucking company large or small as many see bankruptcies occurring weekly possibly daily. Every Carrier & O/o situation is different so it depends on their own business's situation.
  4. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,944
    Oct 31, 2023
    What do you plan to do with your authority while you're running freight as the lease op?
  5. tnc110
    135
    81
    May 22, 2016
    Ideally I would have 2 sets of door signs. Theirs and mine and swap out if I has a load to pull under my authority. But how does my cab card work as far as who is responsible for safety.
  6. wore out
    wore out Numbered Classic
    16,754
    205,001
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The killer in this deal is insurance . You can’t put 2 separate policies with the same coverage on the same truck. As far as cab card you can lease to them and still run your plates and IFTA. The cab card will just have the new authority listed as operated by. Or you can run theirs however the cab card will have the folks you’re leased to listed as operated by. Which means you can’t just swap signs. I see the idea of wanting to make sure it’s going to work before putting your numbers on withdrawal, it just isn’t feasible even if it were doable
    Short Fuse EOD and Oxbow Thank this.
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    What is your goal by doing so?
    I'm leased on with Mercer. And there are several folks running their own authority, not leased on, that primarily pull Mercer loads and grab loads from other brokers only when necessary.
  8. sirjeff
    sirjeff Medium Load Member
    Could you not work something out with them where they broker the work to you for a few more points than they would pay you as a lease op?
    Win win for everyone, no?
  9. Iamoverit
    2,159
    4,944
    Oct 31, 2023
    You'll have to swap your plates along with the door numbers so they match.
    Run your DOT number/signs along with your IRP/cabcard/IFTA/insurance etc etc when you're hauling with your authority.
    Then swap everything with the carrier's that you're leased with when you're running for them.
    Your cab card is your registration. It goes with the plates/IRP/IFTA. The MC responsible for safety is whoever the IRP/plates are under.
    It's really simple. Your stuff for your freight and the carrier's stuff when you're hauling for them.
  10. 062
    062 Road Train Member
    6,288
    33,828
    Oct 20, 2013
    What state will issue a new plate when the truck already has a valid plate?
    D.Tibbitt Thanks this.
  11. Iamoverit
    2,159
    4,944
    Oct 31, 2023
    Call your IRP office. They'll explain it for you.
