Led Headlight Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big Mike 379, Feb 20, 2017.
  1. Big Mike 379
    Big Mike 379 Bobtail Member
    4
    Hi I have a 2008 Kenworth T800, I installed aftermarket LED headlights yesterday. Everything worked as it should yesterday, this morning when I got in the truck and turned the lights on all four lights came on and my bright light symbol was blinking on and off. Anyone else ever have this problem or know what's wrong? Thanks in advance
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Did you have the CECU programmed for LED lights? Probably sensing low current becasue it's programmed for OEM bulbs. You need Paccar ESA and it's just a quick parameter change.
    dustinbrock, Heavyd and SAR Thank this.
  4. Big Mike 379
    4
  5. Big Mike 379
    4
    Would that be why when I just took it all apart and plugged everything back in and turned switch on it worked like it should but soon as I started the truck up it went back to doing the same thing?
  6. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Probably. I am not sure how CECU reacts to input voltage as far as what the acceptable amp range is, but you have 1.5-2 volts more with the truck running, which would change amperage through the bulb. That range would change a lot more for an incandescent lamp than it would for an LED, which are typically cut down to 5 volts in the LED.
    Some LED kits have resistors built in that don't require programming, some do. The instructions should tell you, but I wouldn't be surprised if they don't say on cheaper kits. I do know that in the parameters, lights have an LED or Incandescent option, which changes the acceptable amperage high/low to match the bulbs. If it goes high or low, it sets a fault. A flashing high beam indicator means a headlight fault on your truck and I'm guessing that if you pull the faults, you'll have one for low current.
    SAR Thanks this.
  7. Cat sdp
    Cat sdp . .
    21,204
    75,308
    Apr 8, 2012
    Orion's Belt
    Hope you don't do a lot of snow storm driving....The truck light ones for the W9/T8 are unusable in the snow .
    My low beams are 3 season only I guess :(
    Ruthless Thanks this.
  8. Big Mike 379
    4
    Thankfully when it snows the truck sits lol we're super busy in the winter
  9. Heavyd
    Heavyd Road Train Member
    7,815
    6,268
    Feb 4, 2009
    Many LED only work at 12 volts and higher. LED's in some internationals have a hard time with DRL because they run at a lower voltage, usually around 8 or so to produce the dimmed light. LEDs simply won't function at 8 volts, or if they do they will flicker.
    SAR Thanks this.
  10. Cat sdp
    Cat sdp . .
    21,204
    75,308
    Apr 8, 2012
    Orion's Belt
    I got these...
    Heavyd Thanks this.
