LED map lights and sleeper lights?
Discussion in 'Volvo Forum' started by KB3MMX, Jan 28, 2015.
  1. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Hello, does anyone know the correct bulb replacement numbers to upgrade my incandescent interior lights to all LED , including sleeper lights?
    Truck is a 08' 780
    Thanks!!!!
    -Chuck
  3. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Each manufacturer has diff part numbers but the big map light is a 211-2 and the one beside it is a 5008. It should say on the package what socket the led will fit. You can get the numbers off the others but all should be the same except for the dome and table lights. If not, Google the bulb numbers and you can cross reference and order online
  4. Aleeex
    Aleeex Light Load Member
    150
    78
    Jun 8, 2014
    Sacramento
  5. scooter265
    scooter265 Bobtail Member
    9
    7
    Dec 2, 2014
    Check out 1000Bulbs.com. We have changed out some of our fleet and the guys really can tell the difference. They also have a 800 number on their web page and are more than willing to answer your questions. Most of our installs is the same as Aleeex has stated the 42mm 8 LED style. And yes, Amazon is a little cheaper in price and shipping.
  6. Aleeex
    150
    78
    Jun 8, 2014
    Sacramento
    I prefer the 16 led bulbs. They are slightly brighter and fit just as well as the 8led.
    Also, I bent the tabs slightly together when I installed them so the bulb is held slightly tighter.
  7. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Thank you guys, appreciate the info!!
    -Chuck
  8. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Just to double check, the sleeper overhead lights are a "1156" style bulb or is it a "5008" ??
    Do the 5008 and 1156 have the same base?
    Thanks guys!
  9. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Anybody know the the large sleeper light bulb number?
  10. Aleeex
    150
    78
    Jun 8, 2014
    Sacramento
    Which one??
  11. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    The large one on the roof.
