Legal to nearest scale even when crossing state scales?
Discussion in 'Experienced Truckers' Advice' started by Pmracing, Sep 19, 2018.
  1. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Hello,
    I have been absent from here for a while but this is the best place for DOT info that I know.
    One of our drivers left the shipper and headed to the nearest cat scale (of any scales available). Doing so had crossed an Illinois state scale. Loaded at Manteno IL, rolling I57 N to Monee to scale.
    Well, reportedly He/She was 200-300 overweight on tandems (dispatch could not remember the exact number) and was hit with $545 fine!!!!
    I though we were legal to the nearest scale. How else are we supposed to know if we are legal or not? Safety department says, "It is subject to each state. Go to the nearest scale that does not cross a state scale."
    My question is, Can anyone find written in DOT regulations where we are free from harm (fines) leaving shipper and rolling to nearest scale to check weights.
    Thanks
    Mikeeee
    I have not posted any videos in quite a while. The crazy is so common that it is not exceptional any more.
    rabbiporkchop and 25(2)+2 Thank this.
  3. laaylor
    laaylor Road Train Member
    1,615
    2,451
    Oct 16, 2007
    Creston, Wa
    Nope: you need to be legal weight regardless of how far away the nearest scale is. No exceptions..
    tscottme, 06driver and rabbiporkchop Thank this.
  4. snowwy
    snowwy Road Train Member
    20,584
    13,303
    Jul 6, 2009
    Legal before you leave the property and hit the streets.
    That's a lot of money though for such a petty overweight. Dayung
    Mine was $50 for 1500 over on tandem. Home state.
    $300 in oregon for being 2500 over on bridge.
    06driver, rabbiporkchop and Pmracing Thank this.
  5. ebill45
    ebill45 Light Load Member
    167
    105
    Oct 11, 2011
    dalton ga
    That sound fishy even Illinois will give you 500 pounds on the tandems and just make u slide and get legal. Must caught the wM on bad day
    06driver and Pmracing Thank this.
  6. SteveScott
    SteveScott Road Train Member
    4,897
    16,808
    Nov 10, 2015
    I just found this online. It sounds like the driver may be underestimating the number of pounds he was overweight. My guess it's more like 3,000 instead of 300.
    According to 625 ILCS 5/15-113, the amount of the fine for an overweight truck shall be calculated in accordance to the schedule below (note that additional court costs and surcharges are often added to the amount of the fine). Please note: overweight fines in the City of Chicago can be found under 9-72-080 of the Chicago Municipal Code.
    If the truck is overweight by:
    Up to 2,000 pounds, the ticket shall be $100.
    Between 2001 and 2500 pounds, the ticket shall be $270.
    Between 2501 to 3000 pounds, the ticket shall be $330.
    Between 3001 to 3500 pounds, the ticket shall be $520.
    Between 3501 to 4000 pounds, the ticket shall be $600.
    Between 4001 to 4500 pounds, the ticket shall be $850.
    Between 4501 to 5000 pounds, the ticket shall be $950.
  7. ebill45
    167
    105
    Oct 11, 2011
    dalton ga
    Oh well that explains it. They’ll lock u up for that much. He’s lucky
    CrappieJunkie Thanks this.
  8. Pmracing
    6,354
    3,178
    Jan 28, 2011
    200-300 pounds is only one hole on our trailers! I was pulled in and full stop weigh on a scale, 1500 overweight on tandems way back in my day (7 years) in IL but was green lit, I assume, because I was only 72,000 and tandems very forward that the WM assumed I was headed to a cat scale to adjust them. Maybe this driver was being a D-wad and they slammed Him/Her?
    Mikeeee
  9. Pmracing
    6,354
    3,178
    Jan 28, 2011
    This was not in the Chicago City limits.
    Mikeeee
  10. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    As soon as you pull out on public roads you must be at legal weight. You are subject to being weighed at that moment.
    SixShooterTransport Thanks this.
  11. Pmracing
    6,354
    3,178
    Jan 28, 2011
    How are we to know if we are legal if the shipper does not have a scale?
