My biggest problems with the quick lights are the ones that have the red light cameras on them as well. You are approaching the intersection.. watching the crosswalk sign to determine the light change (I always look at them) and you see its either on 'dont walk' or changing to it, so you start slowing for the traffic light change and it still doesnt change then as soon as you hit about the white line, it changes. You have 2 options.. run through it or slam on your brakes.
(and a lot of the time those signs are pretty good on determining the light change. Not always, but mostly. I am not really sure what lights ya'll are talking about though... Sorry)
Legalize Engine (Jake) Brakes
Discussion in 'Truckers Strike Forum' started by GlobalCannibal77, Jun 28, 2011.
Page 5 of 8
These are usually outside the main cities. It's a big sign before the light with some kind of lights on it that light up before the traffic light switches to yellow. If the sign lights up before you pass it, you won't make it through the intersection before it turns red. They're timed so you can brake normally down to a stop while the light is still green and by the time you get there it's red. That way they can use a shorter yellow without us in the larger trucks having to panic stop or drive paranoid all the time.
Volvo92906 and SheepDog Thank this. -
I always turn it on when I see that sign. You can try and justify it makes me stop sooner so its a safety feature but I especially like revving it up and letting it rip past houses. Don't like the noise don't live next to a road.
Come in to Valley City ND. No engine braking law. It is down hill from both sides since the city is located at the bottom of a gorge. You either smoke the brakes, use the engine brake or cost down into the city on I94 at 80 mph.
I have my mufflers still in place, I use my jake and don't care. hardly any noise coming off my exhaust with the jake engaged.
I can see the reason for the law to be in place until they outlaw straight pipes of any sort across the country. -
That is a gear grinding school rook maneuver.
80k at 6% your gear should be set before ever reaching the bottom, 20mph if necessary.THBatMan8 Thanks this. -
Most states also have laws against operating a vehicle without a muffler, or altering the exhaust system in ANY way to be louder than it was when it came from the manufacturer.
Illinois:
Kentucky:
I never worry about those signs. I use mine if I need to. But then it's pretty muffled, so I doubt it bothers anyone.
A 379 with straight pipes and no jake is louder than mine with the jake on. -
Big Duker Thanks this.
Heck even with the engine brake on, I have to tap the service brakes once and awhile to keep rpms below 2100 rpm.
On a straight road, i don't care to be at a real slow speed when I hit the bottom of a hill or I can't make it up the other side without crawling up in first gear.
Page 5 of 8
