Level 4 warning 2011 prostar
Discussion in 'International Forum' started by dog-c, Dec 26, 2011.
  1. dog-c
    dog-c Road Train Member
    1,852
    1,546
    May 30, 2011
    New York, NY
    Men, I got a level 4 warning that just came on as I was getting a cup of coffee here at green river, Utah conoco, I came back inTo the truck to find it blasting *stop engine, so I need some insight, my coolant was low, (and every day I add coolant at least 1/2 gallon a day), last week the same alarm was going off near Tennessee border, drove it to terminal and had crankcase filter replaced. That seemed to solve the problem until now......oil levels are fine coolant fine I can't go anywhere the nearest international dealer is 100 miles east to co border at grand junction and west.....any advice ?
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Almost sounds like a bad censor....but if it is "shut down" not "warn engine"...you need to send a message to Mr. Haney!
  4. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    I hope is just a internal sensor...any coolant in engine? water in diesel? call service immediatly! keep us posted.
  5. Heavyd
    Heavyd Road Train Member
    7,776
    6,214
    Feb 4, 2009
    Level 4 as in DPF soot loading? If so, you should have gotten level 1, then 2 and then 3 warnings. Did this happen? If you went from all good straight to a level 4 it sounds like there is something wrong with the DPF differential pressure sensor or circuit. But, be honest about the DPF warning lights. There are still a lot of drivers and owners that don't know enough about them and when they need to do a parked regen. Level 1 you get your DPF light coming on solid. Usually just driving a highway speed is enough to burn off the soot. Level 2 is a flashing DPF light. This is a higher level of DPF plugging and now you have to pull over and do a parked regen. Level three is really your last warning, DPF light is on and flashing, CEL is on and dash is beeping. You MUST pull over and do a parked regen. Level 4 is when the engine is sensing extreme DPF plugging that is enough to cause damage. The engine will not let you go above idle. A regen must be done only with a laptop by an International tech. This is tricky to do because without a laptop I think the engine keeps shutting down so it won't get hot enough to even start a parked regen.
  6. Dutch
    Dutch Light Load Member
    194
    58
    Commiefornia
    What engine? As what heavyd said it should go through lvl 1-4, not just go to lvl 4 right away. I have a couple 07 emission maxxforce 13 go right to lvl 4 and not flag the other stages. If the coolant level is low enough it can throw a stop engine light for low coolant. If its using coolant it could be an egr cooler. As for why the stop engine light is on its hard to say with out hooking up a laptop and seeing what fault is triggering it.
  7. Heavyd
    7,776
    6,214
    Feb 4, 2009
    The stop engine light comes on at a level 4 dpf warning.
    dog-c Thanks this.
  8. Dutch
    194
    58
    Commiefornia
    Ya I know that. I get alot of drivers confused with the triangle warning light on the dash saying the regen light is on but the actual regen light isnt on. I was wondering if the triangle + the stop engine, or triangle + stop + dpf light was on.
  9. Heavyd
    7,776
    6,214
    Feb 4, 2009
    Yah, it is confusing, but unless someone ripped it off, everything is there on the backside of the visor.
  10. lv gn
    lv gn Heavy Load Member
    985
    469
    Jun 23, 2008
    las vegas nv.
    On my old pro star that used that much coolant. It was egr cooler.
  11. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    we had a egr cooler go bad when they found it leaking we had been in 3 shops and 2 dealers b4 it should it was leaking but when they changes it they also had to change every thing turbo, dpf, muffler, it was a 09 with a isx
