Leveling valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Mar 14, 2016.
  1. rollin coal
    rollin coal Road Train Member
    13,514
    27,655
    Mar 29, 2008
    TN
    Is it just the new normal for these to go bad after about a year or so? I never had one go bad as a company driver in about 9 years. On my truck in the past six years I have replaced it a half a dozen times. I remember one time right out of the box a brand new haldex was leaking down. These are all made in Mexico. I think that is the only option anymore aside from Chinese.
  3. sawmill
    sawmill Road Train Member
    3,835
    70,709
    May 29, 2015
    Evanston, WY
    I had one that was like that. Turned out to be rust and crud from air tanks, or at least that's what it looks like. Ended up replacing the air tanks when one developed a leak and all of a sudden it quit eating up leveling valves.
    rollin coal Thanks this.
  4. Blackshack46
    Blackshack46 Road Train Member
    Are you sure your putting it on right?
  5. Blackshack46
    Are you replacing just the valve? Or the whole assembly, rod and what else included?
  6. rollin coal
    13,514
    27,655
    Mar 29, 2008
    TN
    Installed correctly yes. If it is crud in the system why only the level valve and none of the other control valves? I did recently have a very minor amount of oil in some moisture when I purge my air tanks but really not a lot. And that doesn't explain all the ones that prematurely went bad in year's prior.
  7. rollin coal
    13,514
    27,655
    Mar 29, 2008
    TN
    Last time I replaced the rod with the level valve.
  8. Blackshack46
    Does it ever work? Or ya put it on, run down the road and the sob is leaking?
  9. mtoo
    mtoo Road Train Member
    1,936
    4,514
    Jan 15, 2011
    Retired on bended knee
    I've only replaced 2 in 30 years, one truck and one trailer. @sawmill might be onto something
  10. rollin coal
    13,514
    27,655
    Mar 29, 2008
    TN
    He could be. I guess I'll take the old one apart as best I can and see if there is any crud or rust flakes or something inside of it.
  11. mtoo
    1,936
    4,514
    Jan 15, 2011
    ride height might effect it. meaning that when the air was out of the bags, it puts the valve in a bind and shortens the life? Does the suspension hold air overnight / weekend?
    Blackshack46 Thanks this.
