Licensing for Flatbed Drivers ?
Discussion in 'Flatbed Trucking Forum' started by Todd Siegal, Aug 7, 2013.
  1. Todd Siegal
    Todd Siegal Bobtail Member
    21
    9
    Sep 4, 2012
    Florida
    Does anyone know the requirements for Driving a "Flatbed Tow Truck" in Fla?
    I'm based out of Fla, but on the road right now and my contacts are not available.
    Your constructive input is greatly appreciated.
  3. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    A class B will allow you to drive a "rollback".
  4. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    U need your flatbed endorsment. You been trolled!!!!
  5. The Bird
    The Bird Medium Load Member
    386
    268
    Apr 10, 2012
    White Rock, NM
    Considering some of the loads I've seen, a flatbed endorsement might not be too bad of an idea.
  6. TripleSix
    132,422
    Only if it helps with freight rates.
  7. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
  8. fisher guy
    fisher guy Road Train Member
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    dont listen to these guys if u just wanna drive a normal flatbed tow truck similar to a F-550 no air brakes up to 26,000lbs gvw no special license is necessary if u wanna move up to a medium duty flatbed/wrecker under 26,001lbs gvw chances are it will have air brakes for that u will need either a cdl B license or take the air brake test and have it added to ur license if u wanna drive the heavy duty wreckers then a class A will be needed possibly with a doubles endorsement florida use to require a class d drivers license for anything with over 8800lbs gvw but since have done away with it i used to have it
  9. fisher guy
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    as long as it is under 26,000lbs gvwr he doesnt need a cdl
