lifter axle and legal weights
Discussion in 'Ask An Owner Operator' started by Abradleyfarms, Mar 10, 2012.
  1. Abradleyfarms
    Abradleyfarms Bobtail Member
    21
    7
    Feb 25, 2012
    Nowhere,ga
    I am looking at a new(to me) truck and trailer. The current setup is irelavent since it's hard to overload a horse trailer with horses. The truck is a single axle with a lift axle in front of the drive. My question is with the lift axle down what is the max weight? Would it be 80K like a regular tandem or split between a single-screw and a tandem? I have tried searching and can't come up with a clear answer. Pics of truck show fullsize duals, not the little tires you see on heavy-hauls and dumps. Just trying to figure this out since a '95 truck with only 280K on a n14 are not that common and this one shouldn't have pulled weight. If you PM me I can't respond yet.
    Thanks
    Andrew
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    It would depend on the specs of the axles on the truck. They could be spec'd for less than the 34K limit, if so you would be limited to the spec, or possibly higher than 34K which then you would be limited to the local regs. Is it a full size class 8 tractor, or a smaller class truck stretched with an extra axle?
  4. twolane
    twolane Medium Load Member
    468
    252
    Dec 16, 2010
    Arizona
    Hope I'm understanding this quest right...
    IF it's on tires and axles common to big-rigs. (not a p/u)
    You are allowed 12,000 on the steer, & 20,000 on a single drive axle for a total of 32,000 lbs on the tractor. Single axle trailers are 20,000 lbs per axle.
    On a"tandem" (set spaced less than 10'2" apart) your allowed 34,000 lbs on that set. Add that to the 12,000 for the steer you now have 46,000 on the tractor. Add the trailers set at 34,000 and now you have a total of 80k.
    Doesn't matter if it's a "tag-axle" or not as long as it's part of a 2 axle set spaced less than 10'2".
  5. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    If the axle is rated accordingly, as well as the tires, then it will be a normal weight axle. So 17,000 per axle assuming a 5 axle setup. 80k lbs gross.
    If the axle is only rated at 12k lbs though, then it will drop.
    Should be a sticker on the drivers door jamb that will list the axle weights and the gross weight of the tractor only. Normally this is 52k lbs with 40k lbs rears.
    To be safe, look at the sticker from the manufacturer.
    I have thought long and hard about a lift instead of the twin screw, but that is where it stops, in my thoughts....:biggrin_2552:
    Martin
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    That is why most trucks with a lift tag or pusher axle have the drive axle spec'd for 23K. To accommodate that 20K on a single axle and handle the torque. Not all do, but most are that way. Need to take a look at the axle plate to see the model number.
    SHC Thanks this.
