Lifting requirement for tanker drivers (for future refrence)
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Nightwind8830, May 29, 2014.
  1. Nightwind8830
    Nightwind8830 Medium Load Member
    419
    192
    Jul 13, 2013
    Chicago,IL
    Are most Tanker drivers required to be able to lift 100lbs above their head,s or dose that vary per company depending on what materials they haul? Before deciding on Roehl, I interviewed at Central Ink in west Chicago. the people were awesome, easy to get along with,the pay and home time were exactly what I wanted, but they required all drivers to be able to lift 100lbs over their head because they haul ink for newspapers and in the winter the 3 inch diameter hoses ,which are around 60 lbs usually,would get stiff and increase in weight. My question is, is this the case with most tanker jobs, are the hoses usually 70-80 lbs normally or does that vary? Im going to look for a tanker driving position after I've acquired an adequate amount of experience driving, so im questioning for future reference.
  3. Criminey Jade
    Criminey Jade Road Train Member
    1,609
    1,803
    Aug 16, 2013
    Not Colorado Anymore
    I have never run into that requirement for tanker work. Are they sure they mean over your head? It isn't safe to be in any situation in which you have to lift that much weight above your head. I have encountered flatbedding jobs which ask that drivers can lift and hold 65 to 100 lbs from ground to shoulder height, but never higher than that.
    The most I needed to hold or pull around at my previous driving job maybe maxed out at 45 lbs.
    Nightwind8830 Thanks this.
  4. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    Personally I wouldn't take a job that requires me to lift 100 lbs over my head. You just try it. Unless you're a fit young man, and have a knack for lifting weights, I wouldn't attempt it. You could easily do yourself an injury
    I've hauled gasoline and now chemicals so I know that what you're saying is def not the norm.
    Yes, hoses full of gas can be heavy, but I never had to lift them over my head. Neither would I say they weigh 100 lbs. IMHO
    I worked for Dupre and I had to do a strength test. But it was nowhere near 100 lbs., virtually anyone could pass that test.
    Tanker companies are not going to want you to lift that kind of weight.
    Good luck.
    Nightwind8830 and Criminey Jade Thank this.
  5. Nightwind8830
    419
    192
    Jul 13, 2013
    Chicago,IL
    I spoke with the hiring manager , Barbara, she had me come out to Central Ink . she showed me the trucks,the ink vats,and the hoses/metal fixtures. She told me in order to pass the companys strength test to get hired,I would need to be able to lift 100lbs over my head. She was pretty specific about that.over the head, not shoulder height,not waist height,she said over my head. She went on to explain how the hoses are heavy as is, I believe she said 70-80 lbs,and that I'd be attaching hoses together and pulling long stretches of hose around,how they get stiffer and heavier in the winter,ect...she went on to tell me how she used to bail hay and do farm work when she was younger and it helped her when she took the strength test to get hired at this company.
    I'm releived to hear its not the norm to have to lift that much weight.
  6. Criminey Jade
    1,609
    1,803
    Aug 16, 2013
    I'd almost be tempted to have OSHA look into their operation.
  7. Dr_Fandango44
    1,053
    746
    Aug 27, 2012
    Austin, TX
    Who cares that this chick worked on a farm. What's that gotta do with anything. I think you're asking for trouble when you expect a driver to haul/ lift that kind of weight in order to do a job. I've never heard of such nonsense. There's a knack to lifting heavy weight. It's not always down to strength alone. Lift that kind of weight the wrong way, and you're gonna have back problems for the rest of your life. No job is that kind of risk.
  8. Nightwind8830
    419
    192
    Jul 13, 2013
    Chicago,IL
    It does sound dangerous, imagine if you dropped it while attempting to lift. Again, I'm glad to hear its not the norm,this was my first experience with anything tanker related and it kinda surprised me how much they wanted people to lift. The hiring manager told me the company was really short on drivers , which is why they were willing to take on a new driver right out of school. ( I was directed to this company by Wolf CDL school,the company emailed the school that they needed drivers)
  9. glenn71
    glenn71 Medium Load Member
    658
    294
    Jul 13, 2013
    Well they probably need drivers because they either get hurt or won't lift that amount of weight that high. Not too many men can lift 100# over their heads unless they have trained to do it. And even fewer women.
    I'm 6' and 190# and I'm strong and in good shape and I seriously doubt I could lift that much over my head. 100# it's a lot heavier than you realize. My old job I used to lug anywhere from 50-85# up and down stairs at chest height and that was a strain if you didn't know how to do it.
    I get the feeling someone inflated the numbers they gave to you, and I wonder why they did that. Could it be that the hr person didn't know what they were talking about (likely), or maybe they were trying to scare you off (less likely, but not unheard of)?
    I don't see someone being required to lift that kind of weight without some form of mechanical or human assistance. I know that no industrial plant would even consider allowing a worker to lift like that. They would be paying out workers comp like crazy.
  10. Nightwind8830
    419
    192
    Jul 13, 2013
    Chicago,IL
    I have no idea,honestly. Im starting to think she did,judgng by everyones reactions,which would suck and makes me feel really awkward.Why tell the school to send you new drivers to begin with?
  11. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    She is just a big ole hay bailing girl who doesn't have time for pencil necked weaklings.
