Lighting problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Aron, Jan 8, 2018.
  1. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    i have a different 1999 w900 l that recently started flashing trailer clearance lights on and off. Light would go dim and then kick out as do the dash lights have checked all grounds I can think of still nothing anything helps thanks!
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,528
    6,586
    Aug 26, 2014
    Do they still have the electrical panel in front of the clutch pedal? Change the relay and breaker for that, look at the connections for them. Where ever they are. If that does not fix it you will have some spares.
  4. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    Changed them didn’t help but I did find out my cab and sleeper top lights won’t come on unless a trailer is plugged in
  5. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    check your pigtail both ends 1 side might be grounding out mine had water on the truck side in plug caused lights to do funny things
  6. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    I agree with the pigtail socket. Cab socket usually is the culprit. I had this happen on a 2013 t700 and it caused the dash to go nuts with key off, and light switches off. You may have a bad interrupt switch also.
    bowhunter67 Thanks this.
  7. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    Tried new pigtail still have problem did notice my top cab lights will no longer come on unless trailer is plugged never had that before checked as much wiring as I could trace different trailer does same thing
  8. Oldironfan
    5,776
    5,544
    May 22, 2017
    Did you replace pigtail sockets. I had to do that on a 2013 t700 it was powering the ecm and all lights and dash would go nuts with key off.
  9. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    Yes they are new on the truck now and doesn’t seem to matter on trailer have tried three all the same
  10. Oldironfan
    5,776
    5,544
    May 22, 2017
    Than you need to get the ground wires checked. Something is not grounding.
  11. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    Do you or anybody know where the trailer pigtail coming forwards grounds in truck?
