lipe clutch vs eaton
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dpfndefbad, Nov 6, 2012.
  1. dpfndefbad
    dpfndefbad Bobtail Member
    35
    Oct 31, 2012
    PA
    Truck is leaking oil out of trans input shaft seal and i gotta split it. Clutch is original and im gonna replace it while is apart. Anyone have any opinions on whether the lipe is better than an eaton as far as longevity? Gonna do it in next couple of weeks.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    lipe hands down!!
  4. dpfndefbad
    35
    Oct 31, 2012
    PA
    Have you used one? How many miles on it?
  5. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    What make of transmition do you have? If its a eaton there is no seal on the input it has a reverse spiral cut into the input shaft that pushes the oil inward.
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Lipe clutch has a lot of good features that make it the hands down choice. The design of the pressure springs is better. Also, it is the easiest clutch in the world to adjust. A simple, one person job. No having to have someone push in the clutch or put a 2x4 block of wood in to hold the clutch in. It is a simple remove the inspection cover, and adjust the ring to the correct distance, then you are done. If you go on Lipe's site, there is a description of the clutch and how to adjust it. You do not need to be some sort of mechanical wiz to do the job.
    Check out this brochure from them. Look at the bottom page. It shows how to adjust a Lipe clutch.
    http://www.setcoautonainc.com/_products/pdfs/new-installation-brochure-lipe-clutch.pdf
    The general site for more info on the Lipe clutches is here:
    http://www.setcoautonainc.com/_products/clutch15-index.htm
    Rickylexy and rollin coal Thank this.
  7. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Where are the best places to purchase a lipe? And best pricing?
  8. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    yes i have, still in the truck pulling heavy haul with no issues. miles are at about 180000. but like 500000 with the weight i drag.
  9. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Do web search. There are several online places who are selling Lipe clutches. A lot of truck dealers are stocking them in parts. But, of course, you will pay full retail getting one there. Might want to check local truck repair shops in your area. They may have access to better pricing. Quick search online, I came up with pricing from $650 for a Lipe 2 (2000 lb torque) to $700 for a Lipe 1 (2400 lb torque). Take your pick.
    http://www.phoenixfriction.com/m-30-lipe-clutch-by-setco.aspx
    Cat sdp Thanks this.
  10. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Mid America Clutch is what I got after my pilot bearing seized up and things needed to be opened up down thar. Made in Indiana.
    Cost was 5 hundred and some Ameros 2 years ago for the entire clutch and release bearing. Built like a Eaton Easy pedal. Beautiful clutch. HAven't had any issues with it. Can't beat the price.
    I've heard of more than one Lipes that have come apart.
  11. dpfndefbad
    35
    Oct 31, 2012
    PA
    Called dealer to order and he said they stopped using them cause had a bunch where throw out bearing went out within a year? You hear about this?
