More issues 2006 Columbia . Air bags not going up due to air pressure . 2nd tank builds about 50 lbs and up to 100 psi if I sit there and rev it up . But does not go over that . No air leaks . Drains both tanks . Lots of water came out of both
Little to no air build up in secondary tank
Discussion in 'Freightliner Forum' started by Dorego401, Oct 14, 2020.
Bypass the Air dryer and if your problem is solved replace it
Does the air governor pop indicating back pressure? If so check your main airline going to the air dryer
PROBLEM FIXED . NEW PROBLEM. Did that, same issue . Just ending up replacing the tank and also replaced check valve . New issue now . Getting good air pressure in both tanks now my airs bags (on truck) won’t go up ! This is bugging me out!!!
How fast does your air drain from 130 to 100?
Check the valve by your 5th wheel . That is what distributes the air to the bags
I just took it for a spin today not going under 100
I’ll have to look for that tomorrow I have a long frame stinger setup
