I have an older 377 Pete with newway air suspension. I raised one side of suspension because it was 1/4 inch low now when loaded my load gauge reads about 10 psi higher 84lbs. Does this sound normal or do I have something else going on? Thanks in advance
Load gauge reads high after adjusting suspension
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jimmy the cat, Nov 4, 2012.
Any time you adjust or replace a levelling valve it will change your "load guage" readings.
Time to load a full load and find a CAT scale. -
Ignore those factory load gauges. They are just another useless gauge to distract your attention from the road. They are not accurate and should never be factored in any calculation for weight. A proper scale should always be used like ralph mentioned. Your gauge now shows different because you have in fact increased the pressure on that side to even out the level side-to-side. You must have dual leveling valves, and the load gauge is only reading off of the one side. It must have been on the side that was low.
Of course if you increase air pressure that it will increase the gauge pressure.
All you have done is gone back to square one... like suggested, hit the CAT scale and learn your gauge again.
btw mine shows 50 psi @ 34,000 yet on my last truck it was 60 psi... the difference was the airbags on the suspension of each truck. -
I guess I'll have to take out my load gauge after 12 years and using it thousands of times.
when you ajust ride height you change weight dsistribution, so use scale to "calibrate" gauge
