Load shift.
Discussion in 'The Welcome Wagon' started by Gearjammer78, May 24, 2017.
  1. Gearjammer78
    Gearjammer78 Bobtail Member
    9
    8
    May 24, 2017
    So i have some concerns. A ups double landed in a ditch this morning about 10 trucks in front of me. I had to hit my brakes pretty hard. As a result, i had load shift. Mt trailer is obviously tilted hard. I only have 26 small pallets. But its rolled steel with total weight of 43000lbs. My boss wants me to run it. I found a warehouse that can fix it but not until morn. As i hate sitting here.... i feel it is the safest option. I have sent her multiple photos and she still insists i run it. Input would be great! Thanks and drive safe all.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    You need to find safe haven and stay put and not move until it's resettled.
    You did good finding a place where that load can be worked again and made safe. Don't YOU worry about it. You are doing exactly what I expect from those whose loads have shifted a bit.
    I once used a large building wall to shift a unsteady load. I can still hear the teasing even today from others. Aww look at heavy doing the fornication on the building... things like that.
    Don't worry. You display what I like best in a trucker. Being safe.
    ExOTR, JReding and Gearjammer78 Thank this.
  4. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Post pics. Can't tell without seeing
    Getsinyourblood Thanks this.
  5. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    Unhook your tractor,tie a strap to your frame and pull the pallets to straighten your load,did it in a pilot last year
    x1Heavy Thanks this.
  6. Gearjammer78
    9
    8
    May 24, 2017
    20170524_125319.jpg 20170524_125319.jpg 20170524_131259.jpg 20170524_125319.jpg
  7. Gearjammer78
    9
    8
    May 24, 2017
  8. Gearjammer78
    9
    8
    May 24, 2017
    Each pallet is about 1700lbs
  9. x1Heavy
    34,016
    42,139
    Mar 5, 2016
    Yup that trailer needs to have it's load removed. I think due to the structural signs of breakage, you will want a new trailer brought to you and load into that.
    Jimmy Hoffa, JReding and mitrucker Thank this.
  10. mitrucker
    mitrucker Road Train Member
    5,423
    10,047
    Dec 15, 2010
    Lapeer, MI
    Smart man. Don't haul that until it's fixed.
    Dye Guardian and x1Heavy Thank this.
  11. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Monday is a long wait see if you can find someplace else and if you can you fix the load hard telling how much they would charge if they moved the load and knowing your boss he will charge you.How far do you have to go?
