Load/Unload times
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by LBZ, Jan 30, 2015.
  1. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    How long does it take for you to load/unload your trailer?
    The reason I am asking is there are big differences to note as trailers change.
    For example mine is a 7 car chain trailer, though mostly use wheel straps. So if 7 cars are loaded,
    am carrying 28 individual ratchets around the cars.
    The photo attached shows an empty stinger(from last year). It was a strap Boystun set up. The guy
    rolled in 15 minutes after me & was done a few minutes before(this includes me rolling up
    each strap to put in the tool box). The kicker is he had 8 Camaros or Challengers & only had
    6 units on my trailer. I had 4 straps per vehicle & will just assume he did as well. You can see my two
    still on my trailer behind his.
    Loading 7 at a rail yard or auction for me is a minimum 2 or 2.5 hours by the time I get the
    cars tracked down, on the trailer, strapped/chained ready to roll down the road. Cars that have
    damage(s) only add to the load time between getting an inspector(rail yard) &/or scribbling all the
    stuff on inspection sheets & possibly having to call the buyer(auction).
    Just curious is all as never really sit & watch other people.
  3. Pullin2
    Pullin2 Crusty Canuck
    1,991
    3,611
    Nov 5, 2011
    Whoville Pub, Long Island
    Last unit I had was a Cottrell High Rail with a Sterling cab and matching head rack. It would take me 2 + hours to strap a load of 9 or 10. And that was for a pulled load beside me. Once I had all the units, checked vins and exceptions, it would take 15 + minutes alone just to unpack the straps and walk them around the truck to their spots. Then the rest was just as you'd expect - load - strap - raise - repeat - stack - pin - go.
    LBZ Thanks this.
  4. Thumper
    Thumper Medium Load Member
    497
    155
    Aug 22, 2008
    With My Units Staged The One ive got now is a 9 car day cab Volvo with next gen low rail trailer takes about 45m
    Had a 10 car sterling ive loaded in 25 minutes the trailer plays a big roll depending on how many times you have to move it to load
    Example
    Volvo
    Load 2 Move decks
    Load 1 Move Decks
    Load 3 Move Decks
    Load 3 Move Decks
    Sterling
    Load 5 Move Decks
    Load 5 Move Decks
    LBZ Thanks this.
  5. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,842
    Jul 28, 2011
    Glasco,Ks.
    Not to hijack Brad's thread, but does anyone else find it odd that when Freightliner killed off Sterling that they either didn't,
    (a) Keep the Sterling AH Cab/chassis and just rebrand it as a Freightliner, or
    (b) Dedicate one of their Freightliner models to Auto Haul?
    It just seems dumb on Freightliners part to kill that truck since it is/was literally the ONLY truck that without cab mods could get down to 90+ inches.
    I know it's not a O/O truck like a Star Car, or Pete, but from a work truck/ OEM sand point, I don't see how you can beat it, and that was 8 years ago already, some minor updates on the truck would have gone a long ways.
    Or am I just goofy?
    Thumper and mnmover Thank this.
  6. Pullin2
    1,991
    3,611
    Nov 5, 2011
    Not goofy Stan. Last I heard was back room dealing with Volvo and International. You wait and see. There will be a new low pro Freightliner sooner then later. I have heard it may come back as a CCC (CraneCarrierCorp) low pro just to keep things interesting. Remember all those cool low pro garbage truck cab and chassis over the years ? And some modified for car haul ? I'm told they're about to go fleet low pro. Under what name, dunno .
    KANSAS TRANSIT Thanks this.
  7. Hammer166
    7,355
    26,463
    Aug 18, 2007
    ~8600+' and loving it!
    The guy at Midway Ford that Cooper deals with spent a lot of time with Freightliner to design the new carhaul chassis. Saw a story about a year or so ago, but I've only see a few a them, since I'm not out and about anymore. Here's a pic:
    Speedloader and KANSAS TRANSIT Thank this.
  8. Hammer166
    7,355
    26,463
    Aug 18, 2007
    As far as load times, it always varied so much, depending on the load, and how much abuse I wanted to put on the body. I've always been anti-short chaining, and that always adds time. I always figured if I had a big load, and was going to try and keep overhangs down ( Iowa will break you of the habit of cheating off the back,) that 90 minutes was a good time for an auction load, maybe two hours for a big 10 car I had to fiddle with a bit. That said, I have put the 10th unit on the truck in hour, and was ready to roll in 20 more minutes. But that was a straight rental load and I was racing an incoming squall line. Guys running the same freight all the time can easily cut a half hour off load time, as they know exactly where to put each unit and can set the pins as they secure the bottom, as they have memorized where they go with what vehicles. I could easily walk and load 8 Fords in under 2 hours after a month straight of ABQ railhead freight. These next-gen quickloaders we have are really quick to load, even the newer guys get down close to an hour within a month or so. But I think they lose as much time on reloads at stops as they gain at the yard, so unless it's straight loads, I don't know they are that great of a timesaver.
    Unload was normally an hour to an hour fifteen, skids out to skids in, if I got to park the units fairly close. I put 10 down in 40 minutes one time, start to finish, when the salesmen were grabbing the cars from skids, which will definitely spoil you!
    I try to teach the new guys that slow will make them fast, that getting a routine and cutting down your steps will make you faster than rushing, and definitely cut down on damages. But I'm just a ramp manager, and what do I know? Sigh!
  9. jerseymc
    jerseymc Bobtail Member
    16
    18
    Jan 22, 2015
    When I was a driver few years back, if I hustle, it would take me about 1 1/2 hours to pull 9 cars and tie them down with 4 chains each car and 2 hours with wheel straps on a chain truck. If the load was staged already, 45 minutes to put on and 30 minutes to pull off. As we all know, this is car hauling, not pier containers, fastest driver out the gate is hardly ever the best car hauler in the yard.
    LBZ, SLANT6, Speedloader and 1 other person Thank this.
  10. LBZ
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    The three items that consume my time are walking to get the vehicles. Have never had them staged.
    Vehicle Inspections.
    Carrying &/or laying out straps.
    With me only being a 7 car, they are pretty much straight forward if loading all in one spot. Load top, raise decks, load bottom.
    The closest I ever got to staged units was when I did it myself on a Sunday. Had cars on the trailer already to deliver Monday morning in the same city & then came back to the auction to reload. Felt kind of spoiled that Monday. :biggrin_255:
  11. LBZ
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    Got to thinking how my above post sounds... the whole process is what takes the longest. :biggrin_25525:
    Guess my point with all of this trying to figure out if I am missing anything. Aside from possibly having cars
    staged or drastic equipment swap.
    Inspections are inspections. Some of the auction units are insane in terms of the amount scratch/dent/ding to note.
    Staging always concerned with me with either the person pulling the units misses something that is damaged
    or worse, something happens out in the loading lot.
    The Elwood rail yard was also suppose to consolidate down the rows by brand, but have not been there this month.
    Theoretically, you should no longer have to go from A to H to ZZ etc.
